Power steering
I sold a 1972 power steering unit to a guy from a 4x4 for his 2x4 project. I'm told tonight there may be a difference in them?
If that be so, what is the difference? I want to give his money back if it won't fit. Thanks Posted via Mobile Device
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
Member #1049
Re: Power steering
They are different and do no interchange.. the 2WD has a tapered and splined sector shaft with a nut to hold on the pitman arm.. the 4X4 has a straight sector shaft with splines on one side and uses a "pinch bolt" to hold the pitman arm on..
Re: Power steering
Ok thank you. I'll get it back.
Posted via Mobile Device Posted via Mobile Device
