01-15-2011, 07:18 PM | #1 |
76 chevy spindle swap with a 68?
just wondering if the spindle and disc brakes off my buddys 76 chevy pickup will work in my 68 c10? and also the automatic crossmember?
01-15-2011, 07:56 PM | #2 |
67-72 parts collector,…
Re: 76 chevy spindle swap with a 68?
The spindles will work with a balljoint and tie rod swap.
Can you get all of the front end or just the spindles?
01-17-2011, 07:09 PM | #3 |
its a rolling chassis and they want $50 for it
01-17-2011, 07:20 PM | #4 |
Well worth the money.
Get it all. Especially the steering linkage and steering box. You will have everything you need except the master cylinder and prop valve,... unless it's still on it.
01-17-2011, 07:26 PM | #5 |
its all there the bodys sitting on the ground next to the truck i figured it would be alot cheaper then buying the kit. but thanks i appreciate the info
01-17-2011, 09:21 PM | #6 |
I'd swap the whole crossmember; less work cause except for a little steering box clearance it bolts in place of the original c-member.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
01-17-2011, 10:38 PM | #7 |
thats what i was thinking but i wasn't sure if it would fit right in or not i havent had the time to measure it up yet, and it has v8 springs in it that would get me by untill i get lowering ones
