Old 01-15-2011, 10:34 PM   #1
richierlb
another too hot question
after installing a new 195f t-stat due to a no heat situation the gauge reads really high. a little back ground to help, old t-stat a stewart/emp 195f with 3-3/16 bypass holes would not get warm enough to give heat, changed to a 195f motorad t-stat, no temp sender change and fired engine warmed up and checked coolant level ,drove for 5-7 miles still gauge seemed high, would get almost to red then cool to about half of normal range like t-stat is cycling open and closed, took temp of coolant after driving with a thermometer reading 169-171 f. have 350/th350, fan clutch, 4row radiator, with vintage air system
1970 chevy c10 305/th350 3.73 open p/s vintage air
richierlb is offline   Reply With Quote
Old 01-15-2011, 10:39 PM   #2
coloradosean2009
coloradosean2009's Avatar
Re: another too hot question
sticking t stat. did you check it before install?
__________________________________________
Sean
1972 C20
2005 4Runner
coloradosean2009 is offline   Reply With Quote
Old 01-15-2011, 10:43 PM   #3
richierlb
yes boiled in water to make sure t-stat was good
