Old 01-15-2011, 10:58 PM   #1
Navy Mechanic
Navy Mechanic's Avatar
New suspension installed...alignment way off
Completed install of 3.5/5 drop kit from ECE. The stance is awesome! I'll post pics later. Installed drop springs and spindles, KYB shocks and relocation mounts, new upper & lower ball joints, outer tie rods, super trac bar & will install new front sway bar later this weekend.
Went from heated & cut springs and my alignment is now jacked as I expected. Toe in and camber is noticeably off. Question is....it's maybe 3 miles to the alignment shop. Do I drive it (carefully) to the shop or can I do damage to the new tires in that short a distance?
"Once a Chief, always a Chief!" MCPO (ret)
03 2500HD- 'Daily driver'
67 Short Fleet- 'Drivable project!'
11 Malibu LTZ- 'The Wife's ride'
Navy Mechanic is offline   Reply With Quote
Old 01-15-2011, 11:03 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: New suspension installed...alignment way off
Got any old wheels and tires you can throw on the front?
Otherwise I would try to get the "toe" close,... and drive it!
Keith
Convert to disc brakes.
Old 01-15-2011, 11:05 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-15-2011, 11:13 PM   #4
Navy Mechanic
No old rubber.
When I installed the new outer tie rods I measured the old ones installed and duplicated the distance. I need to adjust these to correct the toe in, right?
Old 01-15-2011, 11:17 PM   #5
lolife99
lolife99's Avatar
Yes.
The drop spindles arms are moved in a little more than the stock arms.
So your "toe" will be out a little.
Get some help and measure the front side of the tires compared to the back side.
Just get them close.
3 miles won't hurt anything.
Keith
Old 01-15-2011, 11:38 PM   #6
Navy Mechanic
Yes.
Thanks Man...I appreciate it. Don't want to eat up those brand new tires!
