01-15-2011, 11:17 PM | #1 |
Column Shifter
I have a 1965 C10 and I'm changing from an automatic tranny floor shifter to column shift. Does anyone have any ideas on how I go about findin linkage for the existing column shifter to the tranny. Also, i have long tube headers, so would that be in the way of the linkage or anything?
btw the column shifter was previously used on a 3spd manual tranny |
01-15-2011, 11:27 PM | #2 |
Re: Column Shifter
i'm not real certain on this one, but I think it's more than just linkage to change when going from an auto on the floor to an auto on the column - if the column you're trying to hook the automatic to was previously a manual shift column (i.e. 3 on the tree).
Like I said, I'm not certain about this - but I bought an auto column to make the swap from 3 on the tree to the auto on the column. Haven't rebuilt it yet, but the stuff danglin on the end of the column is a little different between 3 on the tree and auto on the column. Anyhoo -I'm interested in what others have to say on this. |
01-23-2011, 06:29 PM | #3 |
Re: Column Shifter
Well after researching some stuff I found that the ididit cable column shifter kit would fit my column. All I have to do is mount it to the column and hook the cable to one of the shifter arms on the column. This is only a theory, but sooner or later I'll see if it'll actually work or not, but I'm pretty confident that it will...
01-23-2011, 06:34 PM | #4 |
Junior Member
Re: Column Shifter
I think that would be true if your column is an automatic column.
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! |
01-23-2011, 06:57 PM | #5 |
Re: Column Shifter
Lokar makes a couple of nice kits.
Available through Summit for around $55.00 part # ACA-1800 http://www.summitracing.com/parts/LOK-ACA-1800/ Or through PACT for around $70.00 #89SLR. http://www.transmissioncenter.com/Lo...er_Linkage.htm GM Adjustable Column Shift Linkage. |
01-23-2011, 08:49 PM | #6 | |
Re: Column Shifter
01-23-2011, 09:06 PM | #7 | |
Re: Column Shifter
01-24-2011, 02:04 PM | #8 |
Re: Column Shifter
the column is an actual 3spd column, but guess I should give Lokar or somebody a call before I start throwing away money... Thanks
01-24-2011, 02:38 PM | #9 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Column Shifter
I used the locar shaft shifter stuff, worked like a charm on my lat 70's tilt and also my stock auto column.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-16-2011, 09:07 PM | #10 |
Re: Column Shifter
I just got a shifter rod and mounted it to my upper arm on my column and it worked fine... but now I plan on just puttin' my other pedal back in makin' it a 3 on the tree
