Old 01-15-2011, 11:41 PM   #1
LedSled71
LedSled71's Avatar
Quick header ?
I've searched the forum to no avail, but are any other headers available for my truck (ie. chevelle, camaro, etc) that would be compatible with my setup without any major modification/trimming. It's just that I bought my truck with hedman long tube headers and constantly have leaks and whatnot, even after the copper gasket upgrade. Now it's to the point that I actually sheared off two of my header bolts inside my head on the passenger side, and the driver side is at the point of rubbing on my lower a arms thus piercing a couple pin holes. Ground clearance is definitely the culprit. Being that i'm an avid waterfowl hunter and from south louisiana i tend to end up on the road less traveled more often than not during hunting season. Plus we don't have a reputation for having the best roads around. Believe me, I'm already searching for my K20 of choice lol! Anyway, i have a 350/350 combo with a/c and power steering and was wondering where to look for a better alternative which would allow me to keep my exhaust inside the frame rails if at all possible. Any input would be greatly appreciated!
LedSled71 is offline   Reply With Quote
Old 01-16-2011, 12:09 AM   #2
Kokomoooo
Re: Quick header ?
When I got my headers, I ordered the ones for a class A motor home. They have thicker flanges (3\8 compared to 1\4") and thicker tubes (14 ga comp to 18 ga). Can't help you in fitment. Mine are Headman Big Block, and still in box. I don't know if the other brands do this or not.
Summit has them small block
http://www.summitracing.com/parts/HED-69890/
they also list 69890-lso I don't know what the difference is but they are over $100 cheaper. Guess you would have to ask them.
Kokomoooo is offline   Reply With Quote
Old 01-16-2011, 12:29 AM   #3
LedSled71
LedSled71's Avatar
Re: Quick header ?
Wow! I guess u learn something new everyday. Those seem to be pretty stout compared to the norm. I never seen those before, but they still wouldn't remedy my ground clearance issues. thanks anyway for the heads up. the search continues.....
Old 01-16-2011, 12:45 AM   #4
Rooster's 67
Rooster's 67's Avatar
Re: Quick header ?
camaro 3/4 length headers but dont fit manuals if i recall something like these:
http://www.summitracing.com/parts/PTE-H8021/
Rooster's 67 is offline   Reply With Quote
Old 01-16-2011, 01:14 AM   #5
Kokomoooo
Re: Quick header ?
Mmmmmmmmm Ledsled71? Now I see!!! DIY time..
Old 01-16-2011, 01:18 AM   #6
LedSled71
LedSled71's Avatar
Re: Quick header ?
Thanks a bunch Rooster! Those seem like they're exactly what i was looking for! And definitely at a great price as well Mission accomplished! Never can get enough of this place. Til' next time!
Old 01-16-2011, 01:26 AM   #7
CircusWagonJim
CircusWagonJim's Avatar
Re: Quick header ?
I used Sanderson (flanges are so thick that gaskets are supposedly "optional")- Used a pair of 3/4 Headers for a Big-Block Chevelle and they fit and performed BEAUTIFULLY! Truck was bagged so I didn't want the standard truck "full-length" style.
CircusWagonJim is offline   Reply With Quote
Old 01-16-2011, 11:37 AM   #8
Ram-Man
Ram-Man's Avatar
Re: Quick header ?
Heres the Hedman 69640. They looked tight at first but I think they are fine. Others have used them here are my pics.
http://67-72chevytrucks.com/vboard/s...d.php?t=435485
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 01-16-2011, 12:16 PM   #9
Re: Quick header ?
Any header will allow inside the rails exhaust. Header fitment isn't much of a problem on these trucks either. The issues that may come up are with manual linkage and/or ground clearance on a low truck. The 3/4 length/car-type headers solve the ground clearance problem but run right through where the manual shift linkage is. With automatics they work fine. When running the exhaust I like to cut 4" holes in the trailing arm crossmember and weld in pipe to put strength back in the crossmember. ECE sells a crossmember with holes for exhaust,as well as giving better clearance for 1pc driveshafts on lowered trucks.
Old 01-16-2011, 12:26 PM   #10
mbgmike
Re: Quick header ?
Just for info we can build any header for any application-not as quick ceramic coat to
mbgmike is offline   Reply With Quote
Old 01-16-2011, 02:22 PM   #11
bigguy69
dazed and confused
bigguy69's Avatar
Re: Quick header ?
good info here
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
