Old 01-16-2011, 12:32 AM   #1
darkone
Will these '05 GMC 3/4 rims fit a '70 c20 chev?
just wondering if these will fit on a 1970 chev c20. both are 8 lug pattern.also, will these fit with low pro tires on a stock height c20?
darkone is offline   Reply With Quote
Old 01-16-2011, 09:02 AM   #2
Blazer1970
Blazer1970's Avatar
Re: Will these '05 GMC 3/4 rims fit a '70 c20 chev?
They will bolt on to the truck just fine. The fit depends on what size wheel and tire you are talking about.
Blazer1970 is offline   Reply With Quote
Old 01-16-2011, 10:00 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You'll probably have issues with how wide they are, the back spacing is too much and the wheel/tire may rub when you turn the wheel.
Old 01-16-2011, 02:32 PM   #4
darkone
thanks for the info ^^ guys. can anyone else give me any more info on rubber that will work with these? again ive got a stock height, all new suspension, 3/4 ton 70 stepside
Old 01-16-2011, 04:18 PM   #5
treveiger
treveiger's Avatar
Not to steal the thread but so lets say i could take the rims off my fathers 05 Dmax and theyll fit on my truck??? Ive threatend it several times but i dont think he believes me.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 01-16-2011, 04:21 PM   #6
capev86
lug pattern is the same, but modern trucks have a different thread size so don't try to use the lugs from the donor unless you change your studs.
capev86 is offline   Reply With Quote
Old 01-16-2011, 06:07 PM   #7
05crewcab
05crewcab's Avatar
Factory Dmax wheels fit just fine but they are inset a tad for most of our liking. I have them on mine, but want to change to something else that fills the wheel wells better.
Darkone, we need the diameter, width and backspace number on those aftermarket wheels above to determine if they will work.
1971 C-20 350/350
05crewcab is offline   Reply With Quote
Old 01-16-2011, 10:32 PM   #8
darkone
thisis what i found for the same wheels at 18"
Size Bolt Pattern Offset Back Space Hub Bore
18 x 10 8x165 -24 mm 4.56" 130.8 mm
18 x 10 8x170 -24 mm 4.56" 130.8 mm
18 x 8.5 8x165 +12 mm 5.22" 130.8 mm
18 x 8.5 8x170 +12 mm 5.22" 130.8 mm
Old 06-29-2021, 07:01 PM   #9
bob arrington
the front fit fine on mine, and I didnt have to but I added a 1 1/2" spacer on each side of the rear to bring them out and fill the rear wheel wells, btw mine were old 2004 american racing 20's.
it changed the rear gear ratio also, its more highway friendly now even with the granny gear 4 speed...lol
bob arrington is offline   Reply With Quote
