Old 01-16-2011, 03:16 AM   #1
custom63
custom63's Avatar
Axle code
Hey everyone.
Im looking to pick up a replacement rearend to upgrade my rear axles to 5x5. I have a line in a '72 1/2 ton rearend but I am unsure of the ratio. The seller said that the axle tube serial code reads thtwo191. Does anybody know what that says about it????? I really need to figure out what the ratio is. I am hopeing to figure it out this way before I drive out and check it out and possibly pop the cover. I wunna know what I have and what I am talkin about before I pull out the cash.
Thanks any and all help.
Tommy~
The difference between genius and stupidity is that genius has its limits
-- Albert Einstein
63 build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=317341
custom63 is offline   Reply With Quote
Old 01-16-2011, 11:21 AM   #2
rideblue00
rideblue00's Avatar
Re: Axle code
I have a book that is called "Chevy truck I.D. numbers" 1946-1972 Based on the code you list my book says its a 1971 3.07 Do not know if its posi or not. There is supposed to be a +- which equals "No Positraction" Im not clear on that tho. I am going to attach a pic of my page its on.
rideblue00 is offline   Reply With Quote
Old 01-16-2011, 01:22 PM   #3
custom63
custom63's Avatar
Re: Axle code
Thanks for the info. They guy said it was out of a '72 though. Could the codes be different for a '72?
Tommy~
-- Albert Einstein
63 build Thread
Old 01-16-2011, 01:24 PM   #4
taclem
taclem's Avatar
Re: Axle code
Is there anywhere else I can get the numbers mentioned above? When I bought my truck it was a '66 long fleet, C10, and I got a short wb frame and also a 292 & 4-spd, nothing is known as to what year any of them other than my cab and front clip are. Thanks, taclem
taclem is offline   Reply With Quote
Old 01-16-2011, 01:28 PM   #5
custom63
custom63's Avatar
Re: Axle code
On your frame there should be a VIN number stamped into it. It should be on the top rail of the frame near the steering box. Is that what you were asking?
Tommy~
-- Albert Einstein
63 build Thread
Old 01-16-2011, 01:55 PM   #6
taclem
taclem's Avatar
Re: Axle code
no, the frame that is under it now I need to decode so I may find the rear ratio, it must be one of the lower ones because I sure could use another gear. The original frame I still have the back half for a trailer. What I am thinking is that maybe I could swap out the rear ends if the original rear end is from an automatic which should be a higher ratio. I just tried to ID the original vin number and the source I was using said it was a suburban, not hardly.
Thanks again, taclem
Old 01-16-2011, 02:05 PM   #7
custom63
custom63's Avatar
Re: Axle code
Does anybody have any other thoughts on my axle question?
Tommy~
-- Albert Einstein
63 build Thread
Old 01-16-2011, 02:57 PM   #8
steverino66
Re: Axle code
Anything is possible on these old trucks - my 66 has a Frankenstein sort of 64 rear end housing with a GM posi unit from a 71 C10, new 3.42 gears and CPP 5-lug axles!
I'd pull the rear cover to be sure of what's in there.
steverino66 is offline   Reply With Quote
Old 01-16-2011, 03:46 PM   #9
custom63
custom63's Avatar
Re: Axle code
I also have an axle tube code for a 1971 Chevy 1/2 ton van. Which is TPJWO56. Anybody know any info on this one? BTW do the Van rearends differ from that of the truck ones. Like widths and brakes etc. Im looking to put this under my '63 for a 5x5 swap. Ive thought about just redrilling my current axles or buying the $500 axle kit from CPP. But I also have a limited amount of funds with still alot to do to my truck. So Im looking for the best option for the money.
Thanks again guys, This site is great.
Tommy~
-- Albert Einstein
63 build Thread
Old 01-16-2011, 06:27 PM   #10
rideblue00
rideblue00's Avatar
Re: Axle code
TPJ 3.07 shows for 1970 C10 pickup.The codes are different every year. TACLEM: you need the numbers off the axle. Frame numbers wont tell you.
Old 01-16-2011, 07:56 PM   #11
rideblue00
rideblue00's Avatar
Re: Axle code
BTW, do the axle swap if its in good working order and its from another trailing arm setup. I dont have any info on the width of these axles. I have read on this forum that the 67-72 axles are 1 inch or so wider. 73-87 years are wider still. I also agree with steverino on taking the cover off to be sure of axle ratio and posi status. as far as redrilling axles go thats fine just make sure you find a drum that fits. Im not sure about redrilling drums. I suppose you can if you have life left in them. Most people use a newer 5 lug drum. But be aware of the new drum center hole size. It will need to match the axle boss.
Old 01-16-2011, 08:17 PM   #12
custom63
custom63's Avatar
Re: Axle code
Both these axles are from a spring setup so I would have to weld new perches, so it would not be a direct bolt in. Ive heard of the redrill process just unsure of it. Gotta find a shop that knows what they are doing. I am also unsure of what ratio I want. My current 6 lug on my '63 is a 3:73 non posi and I am pretty sure the two rearends Im looking at are 3:07. My current engine is a IL250 with a TH350 tranny but I may or may not be changing that, budget will decide that one. Thoughts? BTW the rearends for sale are priced at $40 for the 1970 Van one but its a 2 hr drive away and $100 for the 1972 truck one thats only 30 min away. Both are fully complete drum to drum.
Tommy~
-- Albert Einstein
63 build Thread
Old 01-16-2011, 09:25 PM   #13
LT1 Burb
LT1 Burb's Avatar
Re: Axle code
The leaf spring rear end must be out of a GMC and it will be 1-1/2" wider than a 60-66 rear end. I would think with your drive line you would want to lean to a 3:08 ratio anyways unless you have a tall tire. It would give you better mileage but performance will suffer a little. The other thing you can do is mark the drum and mark the yoke, turn the drum and make one revolution while you count the revs of the yoke.
LT1 Burb is offline   Reply With Quote
Old 01-16-2011, 09:31 PM   #14
rideblue00
rideblue00's Avatar
Re: Axle code
Based on the codes you provided, they are both 1/2 ton pickup rearends. A 1970 an 71 years. If they are leaf spring rears i feel it would be cheaper to modify those. If you are not going to run a overdrive auto trans or 5 speed overdrive manual trans, then you need a 3.07, or 3.42 rear gears. Or you can stay with 3.73. Everybody gets excited about the RPM's being to high, but that what these trucks were designed with. Mine is a 3/4 ton with 4.56 and 4 speed behind a 292 6cyl. If you only drive it some times, leave it stock. I drive twice a week and its fine. If you want to drive it daily and want to save gas, get a 700r4 with a mechanical speedo hookup. Keep the stock rearend then.
Old 01-16-2011, 09:36 PM   #15
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Re: Axle code
custom, is it a '71 Van or a '70 Van (you said '71 earlier and '70 just above) '70 would be 6 lug, '71 would be 5 lug. shouldn't be any difference in width from van to pickup but they'll both be 1.5 inches wider than what you have now. you have leaf springs now or coils?(you said both the axels were from 'spring' setups but didn't state whether they were coil or leaf. starting in '73 the rears are leaf which might make the swap easier is you currently have leafs
Larry
fleetsidelarry is offline   Reply With Quote
Old 01-16-2011, 11:02 PM   #16
stealth_weapons
Re: Axle code
i was trying to find this information 3 days ago. searched all over the interwebs and came up with zilch. do you have the info for a 63? so when i find the numbers i will alreeady know what they are
stealth_weapons is offline   Reply With Quote
Old 01-16-2011, 11:26 PM   #17
rideblue00
rideblue00's Avatar
Re: Axle code
Find your numbers first. I will look them up in my book.
Old 01-16-2011, 11:49 PM   #18
stealth_weapons
Re: Axle code
i found some. they dont follow the code though. one was GM7 the other was 3817763N
Old 01-17-2011, 12:01 AM   #19
custom63
custom63's Avatar
Re: Axle code
Good catch Larry. Its been a long day. Anyways, it is a '71 Van 5 lug and a '72 truck 5 lug both half tons. Both the rearends are setup for leaf springs not coils like my '63 has. If I go with the 3:07 set how much of a dog will she be? I live in an area with kinda alot of hills. I want to pull the trigger on something. Either it be one of these rearend or look into redrilling the axles and turning down the center hubs and matching them up with a later model drum or I have also found an axle kit through ECE to setup on my '63's current rearend that has a 3:73 gear set. Its not bad for $319 but the thing I noticed was that it does not say anything about a spider gear set and I was under the impression that you have to also change out your spider gear set on the '63 and 64 year rearend cuz they are a 17 spine setup and your upgrading to 30 spines with the kit. Has anybody on here used one of these setups on a 63 or 63 truck??
Tommy~
-- Albert Einstein
63 build Thread
Old 01-17-2011, 12:12 AM   #20
Rich 5150 69
Rich 5150 69's Avatar
Re: Axle code
Just a thought your pushing 3,800 lbs with a six, approx 200 hp, with a th 350 and 307 gears, your not gonna burn up the hills in Auburn, I drove a `65 with a 6 and three speed with 342 gears, and was at the bottom of second gear at Eldorado Hill in Cameron park.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-17-2011, 12:16 AM   #21
custom63
custom63's Avatar
Re: Axle code
So whats your thoughts. Go with the 373 to make the best of the IL6? Or try and pony up some $$$$ with a different drive train?
Tommy~
-- Albert Einstein
63 build Thread
Old 01-17-2011, 09:39 AM   #22
fleetsidelarry
Senior Car Nut
Re: Axle code
Stealth, you need to look for numbers stamped into the axel tube (forward passenger side I think) They can be very tough to find, you often have to clean the tube down to bare metal
here in coastal Georgia you'd be ok with the 3.07, but from Rich's comment, I think you'd be better off with the 3.73s. plus, if you ever upgrade to an overdrive, you'll have the best of both worlds. what will it cost just to get your axels filled and drilled?
Larry
Old 01-17-2011, 09:02 PM   #23
custom63
custom63's Avatar
Re: Axle code
I think thats it, um going to stick with the 373 setup. I need to contact some local machine shops and see who can do the fill and drill method, if they have ever done it and what they charge. I am also going to look more into the mentioned ECE axle kit they sell for $319 as well. Im still wondering about that spider gear issue.
Tommy~
-- Albert Einstein
63 build Thread
Old 01-17-2011, 09:11 PM   #24
Rich 5150 69
Re: Axle code
Tommy you can always upgrade that TH350 to a 7004r or 2004r at a later date, 2004r would be just a swap for your th350 the 7004r will require a drive shaft mod...
Old 01-17-2011, 09:36 PM   #25
k1rodeoboater
Re: Axle code
I'm gonna follow this thread, I want to convert my rear to 5 lug as well once I convert my fronts to a disc setup. My plan was to have my rear axles welded and redrilled, though the kits from ECE or CPP may be the way to go.
k1rodeoboater is offline   Reply With Quote
