Old 01-16-2011, 03:52 AM   #1
Nova70
Nova70's Avatar
Gas tank leak- What do I need?
My gas tank leaks when I fill it full. I'm not sure if I need a new gasket or what so was hoping someone could help me. It leaks where the tube goes into the sending unit hole. Hope that makes sense? The tube that runs the height of the tank and then through the floor. Is there a gasket to reseal in up or what? If I need to take a picture I can tomorrow. Thanks for the help.
'70 K10-- 4" lift on 35"s-- For Sale
http://www.ksl.com/index.php?sid=733...iew&ad=4578305
Nova70 is offline   Reply With Quote
Old 01-16-2011, 06:55 AM   #2
JimKshortstep4x4
Re: Gas tank leak- What do I need?
Is it leaking around the tube or is it leaking from the "O" ring that seals the sending unit to the tank?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-16-2011, 07:34 AM   #3
cdowns
cdowns's Avatar
i'd remove the sending unint clean both areas really good install with a new Oring/// this is best done when the gastank is near empty
Old 01-16-2011, 11:26 AM   #4
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
It's probably leaking around the outlet tube. I had the same thing with one of my trucks... I thought it was a gasket but, after looking at it more closely, found there were little cracks in the welds around the tube. Get a new gasket and sending unit and replace them both. That what I did and never had another problem with it.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 01-16-2011, 12:08 PM   #5
Nova70
Nova70's Avatar
It's leaking around the outlet tube, not the sending unit. Guess I'll see how much a new sending unit is.
Edit- Thanks for the reply's guys.
Old 01-16-2011, 09:33 PM   #6
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Are you talking about the fuel line that comes out of the tank? If so, check real closely where it is welded... That is where I had my problem. I initially thought it was a gasket but when I took the sending unit out, the gasket was fine. When you're taking it out, make sure you use a brass punch to get the collar off... They won't create any spark which could be a bad thing around your gas tank.
1978 Chevy C/10 SWB
1970 Pontiac Lemans
Old 01-16-2011, 09:50 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Sending units run about $30-$40. Check the local vendor site or google it.
Also, when removing and reinstalling the sending, use a brass drift. Harbor freight or local auto parts will carry them.
68gmsee is offline   Reply With Quote
