Old 01-16-2011, 07:40 AM   #1
72freak
Rottenwood Garage Member
72freak's Avatar
Front wheel center bore too big issue...what to do?
Ive searched for a thread I have read but I cant find it. As we all know the front drums on all these 6 lug trucks require such a large "center bore" on the rims we are limited on the wheels we can run. Im not interested at this time in doing a major running gear conversion but I have seen threads on milling the wheels OR changing the front brake drums and bearings over to those from a 6 lug car or van. I have read the thread but I cant find it.
I really want to run some 17, 18, or 20's in a 6 lug Torq Thrust style rim.
Thread links, ideas or help would be appreciated.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 01-17-2011, 12:58 AM   #2
Captainfab
60-66 Nut
Re: Front wheel center bore too big issue...what to do?
It has been my understanding that most if not all aftermarket wheels had a center bore large enough to fit the hubs on these older trucks. I could be wrong though on some of the newer larger diameter wheels. I'm not aware of any hubs and drums that can be swapped onto the '63-'70 spindles that will have a smaller hub register.
Old 01-17-2011, 07:15 AM   #3
72freak
72freak's Avatar
You are correct....there are 1000's of wheels made for our 6 lug trucks....unfortunatley, there are several STYLES of wheels that look VERY good that do not come in a center bore large enough to go on them. The 6 lug torq thrust style wheels offered by many companies is one of them. Go to any wheel site and find the center bore size for our trucks...I think its 4.25 and then look at all the 6 lug wheels that are 3.50, 3.75 and so on. There are a lot of threads on this site about miling them down. Summit, Coys, American Racing. I assure you there is also a thread on this site somewhere about swapping drums to car or van drums for a smaller center bore. I read it about a year ago. They may have been Pontiacdrums and bearings...I just cant remember. Hopefully some one will be able to find it.
Old 02-06-2011, 08:48 AM   #4
72freak
72freak's Avatar
Ttt
Old 02-06-2011, 11:54 AM   #5
padresag
you can always have them machined to fit. the hubs on my trailer are a little to big for the set of rallye wheels that I have , so I am just going to chuck them up and machine the hubs down a bit to fit
ron
padresag is offline   Reply With Quote
Old 02-06-2011, 12:29 PM   #6
slepysal
slepysal's Avatar
Most wheel manufactures make there wheels with the bigger hub hole and use "hub centrict"rings that allow the wheels to fit the newer smaller hole hub this saves them money and invantory.
The catch comes when the wheels are made for specifc applications. Newer 6 lug Chevy/ GMC use the smallar hub bore and require a medium off set wheel of up to +20MM,ours take a standard or zero off set or a reversed (deep dish) off set in some cases.
What type and size of wheel were you looking for?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 02-06-2011, 01:30 PM   #7
protrash64
Resistance is Futile
protrash64's Avatar
If you have disc's up front they fit just fine.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
