Old 03-11-2003, 06:50 PM   #1
72Bob
72Bob's Avatar
Crusie Control, Factory 72?
I any ideas what this crusie control is out of? Was there factory crusie control in 68-72's?
I found this in the bottom of a box which had a wiring harness I bought for my 1972 pickup.
Words on the side of the control box,
Made by Dana Corp
Perfect Circle
Controls DIV USA
72BOB
72Bob is offline   Reply With Quote
Old 03-11-2003, 06:51 PM   #2
72Bob
72Bob's Avatar
Another Pic of the Controls
Another pic of the controls
Old 03-11-2003, 09:05 PM   #3
Huck
Huck's Avatar
Believe the factory cruse on a 72 truck had a under dash button control verses a turn lever attached control. That looks like an aftermarket or dealer installed option.
Huck is offline   Reply With Quote
Old 03-11-2003, 09:09 PM   #4
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
I don't think thats a factory 68-72. The switch is wrong. Thats a late 70's switch. Rod had a pic of the factory set up and posted it one time. Might have come out of a later model truck. Of course that doesn't mean it won't work, just not original. Good luck, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 03-11-2003, 09:30 PM   #5
lazygaurd
I have the same set up in my 72 Jimmy, and I am guessing that it was a dealer option. I took mine out and I had to put in a longer speedo cable, as well as put the wiring back to stock on the neutral safety switch.
lazygaurd is offline   Reply With Quote
Old 03-11-2003, 10:07 PM   #6
Rod
NOS
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 03-11-2003, 10:09 PM   #7
cheyguy
cheyguy's Avatar
The stock cruise that was on my dads 72 was on the turnsignal, but it looked like a regular turnsignal lever with a single button on the end, and it just said cruise with an arrow. That looks aftermarket to me!
'71 Cheyenne Super
'80 Custom Deluxe
'75 Blazer
cheyguy is offline   Reply With Quote
Old 03-11-2003, 10:47 PM   #8
Andy4639
Old member
Andy4639's Avatar
Cool Factory Cruise control
This is the picture straight out of the shop manual. It shows all the parts for a factory cruise.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-11-2003, 10:54 PM   #9
Desert Rat
Desert Rat's Avatar
The one you have has the same brain/transducer as the late 60s early 70s Oldsmobiles and Buicks.My brother has a stock identical looking unit on his 442.and my stepdad on his 442.I have a couple of those also.the switch however looks aftermarket to me,or a later model.the factory 68-71 style cruise had a chrome handle with a button in the end.and the 72 had the switch under the dash that says cruise master.I have a 68 style for sale,and another out of a 70 thats missing a couple pieces.the turn signal handle is the same as ive removed from the 68 style Impalas,Chevelles,and Camaros.I have a nice unit out of a 69 427 Caprice also.
Desert Rat is offline   Reply With Quote
Old 03-11-2003, 10:59 PM   #10
spinning wheels
spinning wheels's Avatar
I had/have that same setup on my '72 3/4 ton. If its like mine, it doesn't work I have removed most of it, but the speedo cable is still hooked up to what appears to be a complex thingamajig. The best place to store that cruse control is at a local landfill. That's just MHO.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 03-12-2003, 11:05 AM   #11
72Bob
72Bob's Avatar
Thanks for the help
Thanks for all your help. I guess I did not get that "Lucky Find"
72BOB
