What is this bracket for?
I put my auto trans linkage in last night and cannot figure out what this bracket is for. Its bolted to the frame right near the auto linkage bracket and doesn't seem to do anything. Anyone know what it's for?
Thanks! PS. I'm talking about the bracket with the round hole to the left of the trans linkage bracket.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. Last edited by FL71C10; 01-16-2011 at 10:29 AM. |
Cruzin
Re: What is this bracket for?
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
cant tell your pic is a little blurry
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
Ok, pic is posted now. Sorry about that. Couldn't get it off my phone so I had to put it on the computer first.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
Cruzin
there is an L shaped piece of linkage that one end was held by the frame with that bracket like that i've seen, and the short end went into the U shaped piece on the trans. here is a pic i found of the linkage it has a spring and stuff that goes with it i believe.
The was the truck stick. It looks like it's for the clutch linkage.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 01-16-2011 at 10:53 AM. |
that is there for auto transmission linkage I believe....
There is a plastic ball socket that goes in it if it's tha same thing I'm thinking about |
#8 | |
The truck is a 350 automatic originally. I know it has had several motors ssin it, so who knows. The trans crossmember rivets have all been taken out and is bolted in now. I think the truck last had a 700r4 transmission in it. Maybe some linkage bracket for that?
laying low
![]() Join Date: Mar 2001
That bracket FL is questioning goes with the auto linkage Hub posted and both are for 73 up trucks. The other brackets in FL's pic are correct for the 67-72 trucks. I have a pic somewhere if I can pull it up.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
So it's probably something from one of the other transmissions that were in the truck at some point. I guess I'll take it out.
Thanks!
Correct. I just got a linkage set off a 76 and it included that piece.
-Scott- |
