Old 01-16-2011, 12:30 PM   #1
Jerblazer72
Other years with compatible rear driveshaft?
Everyone,
I am hoping for some more traffic here than in the Tech section, maybe one of the Moderators wants to move this post.
The dilemma I have is that I have a 72 GMC LWB with 4wd. I put a 6 inch lift on the truck and the rear driveshaft needs to be lengthened. I took it to the local shop here in Utah and they said they could no longer get the tube in the correct diameter to lengthen the shaft (4 inch I think they said). Anyway, they wanted over 400 bucks to build one from scratch and I just cant stomach that sort of cash for a driveshaft. I am thinking I can go to the boneyard and find a shft that is 3.5 diameter tube (they said that was the most common size) and make sure it has the correct yoke ends and u-joint sizes and have them lengthen that one. They said even cheaper if I could find one that is too long and they can shorten it for less than if they have to lengthen it. Anyway, I doubt if I am the first one to experience this issue and am wondering if anyone knows where to start with makes or models of trucks to start lookng at to find a suitable donor truck with a rear driveshaft that may work. Thanks in advance for replys.
Jerblazer72 is offline   Reply With Quote
Old 01-16-2011, 01:10 PM   #2
Rod
Re: Other years with compatible rear driveshaft?
I'd search out truck scrap yards for a 2wd drive shaft and have them cut it down. I once owned a 1987 GMC truck with V6 engines and a turbo 400 tranny that had a healthy size drive shaft and was aluminum also. Those drives shafts have been discussed on here before for similar purpose and as a 2wd one piece modification. There should be others also that would work but a 2 wd drive shaft should have plenty of lenght to cut down to your requirements for a much shorter 4x4 lenght even with a lift.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
