Old 01-16-2011, 01:19 PM   #1
Critter
Future TOTM Winner
Critter's Avatar
Relocated Coil packs
I know a few of you have removed the coil packs from the valve covers, where did you put them exactly? Inside the cab or on the firewall somewhere?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 01-16-2011, 01:37 PM   #2
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: Relocated Coil packs
There is one fellow on here that put them inside the frame rails, I think it is Matthew:
http://67-72chevytrucks.com/vboard/member.php?u=41369
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 01-16-2011, 04:22 PM   #3
Mr. 250r
Mr. 250r's Avatar
not sure if you were wanting to buy a kit from someone which i think is 200-300$ or make them yourself but i see alot of people do inside of frame rails or back of motor here's a premade kit http://store.katechengines.com/coil-...n-kits-c7.aspx
Mr. 250r is offline   Reply With Quote
Old 01-17-2011, 03:50 AM   #4
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Yeah that was me that relocated them into the frame rail slight back from the engine one on either side. So far it seems like they work really good. The wiring harness from the PCM didn't even need to be extended. I used 96+ Chevy truck plug wires which sort of work but could be a bit longer and better fitting. I don't think I have any pictures of the relocate I can get some tomorrow if you want.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 01-17-2011, 01:19 PM   #5
Mr. 250r
Mr. 250r's Avatar
i would like to hide mine when i do it but for a mud truck in the frame rails isn't the best spot but now im starting to like how they look on valve covers
Old 01-17-2011, 03:27 PM   #6
Critter
Future TOTM Winner
Critter's Avatar
I'm still up in the air on it. I love the look of them removed, but not sure if it's worth it on my Blazer. It isn't going to be a one-off custom show truck or anything. I'm kinda going for the "Blazer that Chevy SHOULD have built" look and I guess keeping that in mind a stock looking engine isn't the end of the world. When I started this thread I had visions of hiding them in the cab/under the dash.
Old 01-18-2011, 05:26 PM   #7
jkade
jkade's Avatar
My old man relocated them to the back of the motor on his 66 vette, he made some brackets that used the bellhousing bolts. You can't see them in the pic but this is what his motor looked like.
jkade is offline   Reply With Quote
Old 01-18-2011, 05:35 PM   #8
Mr. 250r
Mr. 250r's Avatar
dam that's nice and is the intake flipped around
Old 01-18-2011, 05:53 PM   #9
jkade
jkade's Avatar
Yeah, the intake always got folks.... that was a running piece of plunder there, that car was wicked fast.
Old 01-23-2011, 11:37 PM   #10
65Short
Do you have any more pictures of the coil packs? Or for that matter, the car and engine bay? I love it when people work to make things look so simple and smooth.
65Short is offline   Reply With Quote
