01-16-2011, 01:40 PM | #1 |
2.5" rams horn exhaust manifolds
Does anybody know if there are new 2.5" rams horn exhaust manifolds for sale for our trucks?
I know the 2" are.
06 BMW 330d aut touring full option 83 Jeep CJ7 360 aut sold 71 GMC Suburban 67 Chevrolet C10 stepside 54 Ford F100 sold 49 Chevrolet coe 48 Ford f6 coe Strijen the Netherlands "NO MISTAKES NO PROGRESS" |
01-16-2011, 04:28 PM | #2 |
Watch out for your cornhole !
Re: 2.5" rams horn exhaust manifolds
Sure, you can get 2.5 ramshorns from a lot of places. The reason you're having a hard time finding them is that they are called Vette manifolds. Trucks had 2 inch, Vettes 2.5 inch.
Last I saw, Summit has them under the Dorman brand.
01-16-2011, 05:55 PM | #3 |
Thanx TX Firefighter, but will they fit, because they go straight down instead of angle a bit?
01-16-2011, 07:04 PM | #4 |
I don't know about fit;
but Speedway Motors carries them also.
1972 C30 Cheyenne Super 1971 C10 (Parts truck) |
01-16-2011, 07:37 PM | #5 |
laying low
I hear the straight down horns in a 2 wheel drive setup it's a real tight turn with the headpipes clearing the crossmember and oil filter, starter. In a 4 wd setup it may work.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
01-16-2011, 07:44 PM | #6 |
I've got em in my 4x4 and the right side works fine on a 4x2, but the left is where you have a really tight fit... oh and I got mine on Ebay but had to grind a lot of slag and the old style alt bracket off as well.
01-16-2011, 07:53 PM | #7 |
Rottenwood Garage Member
2x4's you have to have a good exhaust man or pipe fabricator to make it work unless the engine is slid back. Anything is possible....Im about to do it.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
01-16-2011, 08:21 PM | #8 |
That's a good thought - 6 cyl frame mounts will move the engine back to the same spot as a 4x4 the crossmember might still be close but much better -
Posted via Mobile Device |
01-16-2011, 08:42 PM | #9 |
I can confirm both.
The straight dump manifolds are a challenge for the exhaust shop on V8 engine mounts. It can be done, just takes more finesse. And, the inline 6 engine mounts mounts move it far enough back to make the pipes very easy. You just have to decide what route is best for you in light of having to shorten the driveshaft and monkey with the shift linkage when moving the engine back.
01-16-2011, 09:53 PM | #10 |
Born Psycho
i've got 26 years in the same muffler shop and the straight dump 2 1/2 manifolds are a pain in the a$$ on a 2wd with the motor in the stock location. it CAN be done but it's not fun. unless the shop has a modern bender the bends won't be pretty either. i believe the vette manifolds are still available from GM, that's where i bought mine a few years back. i did have to cut off the old style generator/alternator brackets. they are the next best option to headers-without the leaks,lol.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
01-17-2011, 04:11 AM | #11 |
OK guys thanks for the advice. My engine is slid back a little and I know a good exhaustshop so I'm going to try it.
For what I read they are less noisyer and not leaking again and again like my headers. ronald
01-24-2011, 09:38 PM | #12 |
Here is some on Jegs, I will be ordering these shortly for my 70 4x4 'burb. They are the 2.5 incher's.....http://www.jegs.com/i/Wysco/938/MA03...0002/-1:metal:
Looking for some more 67-72 members on Facebook! http://www.facebook.com/pages/1967-1...12378278777413 |
01-24-2011, 11:04 PM | #13 |
69 swb stepside, rebuild and upgrade in progress |
01-24-2011, 11:30 PM | #14 |
Happy to be here
They clean really pretty too...
01-25-2011, 04:43 AM | #15 | |
Don't know if that make's that much of a difference??
01-25-2011, 12:05 PM | #16 |
Those Jegs exhaust manifolds look great, I would guess I put at least 2 hours of clean up into the China made ones I bought on Ebay and they look almost that good.
02-07-2011, 05:31 AM | #17 |
I just ordered a set of 2.5's and my engine is in the stock V8 possition. I should have it to the muffler shop next week. I will post pictures if he can do it.
02-07-2011, 09:02 AM | #18 |
Another option instead of the Ram Horns is C4 (84-96) Corvette manifolds. There are 2 styles, one for the Cross-Fire and Tuned-Port engines and another for the LT1s. The Early one is like a mini header. The LT1 one is cast iron. Both have true 2 1/2" outlets and both are overall dimensionally similar to a ram-horn manifold. If you buy the LT1 ones, insist on removing the heat shield before you buy. Some have a bad habit of cracking.
By the way, on a Corvette the last application of the 2 1/2" ram-horn was in '63. All the way '64-82 the outlet on a small-block was 2". Some of the hi-po small blocks had 2 1/2" exhaust, but they were 2" off the manifold and became 2 1/2" where they turned back. It is tight on a SB '63-82 Corvette on the right side idler arm using 2 1/2" in this area.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
02-08-2011, 03:48 PM | #19 |
i have a set of the vette manifolds, i just replaced them with headers, do they really flow better than most headers? i like the sound of the headers more.
1972 longbed- 454 1967 shortbed- 355 |
02-08-2011, 04:03 PM | #20 |
Headers will always be king when it comes to sound...but you have to constantly tighten the header bolts or deal with exhaust leaks and replacing manifold gaskets. I have herd some trucks with the maifolds that sound great, too. Manifolds are just a little quieter.
Rottenwood Garage 1970...71...72 C1500 aka Orange aka Sideshow Bob 540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600 2 Tons of Fun |
02-09-2011, 09:09 PM | #21 | |
Not too old to learn
Of course after I went out and located a beautiful set of Ram Horns with the alternator mount lugs on passenger side, and had a shop bend up a set of pipes back to under the cab ready for mufflers. Then like a real dummy just now looked at the specs for the engine. Been reading a lot of exhausting lol detail about problems installing 2 1/2 pipes, and you come up with Vette 2" manifolds into 2 1/2"head pipe. I wonder if the engine will be that much affected by the smaller exhaust size ? If for performance , racing and breaking things loss every one in awhile ya, but for every cruising?
1968 C10 a way to long restoration. |
02-09-2011, 09:30 PM | #22 |
I have the 2 1/2" vette style installed on my truck. It is very tight to the starter but possible. My exhaust is 2 1/2" polished tube tucked up into the frame.
My build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=371235 |
02-10-2011, 12:33 AM | #23 |
heymoe:That is a great looking drive line. Was that your idea on pipe routing ?
The starter appears smaller than stock ?
02-10-2011, 01:30 AM | #24 |
This thing looks great! Do you have any more pics (close up) of the manifolds and there closeness?
72 Cheyenne shorty "CheyLow" 72 3/4 long 4X4 69 SWB "Prospector" 68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled" Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com |
02-10-2011, 01:34 AM | #25 |
