"brand new second-hand"
just to add more info on "Hi Hump" vs" Low Hump' trans covers
I swapped a 454 into my 69 a couple of years ago. The ruck was orginal with a 350/turbo 400 and a factory low hump trans cover. I think I know why the factory put a hi hump with big block/400 applications. I have spent two days trying to replace the oil pan gasket on my truck. I finally slid the trans back about 5 inches and jacked the motor uo about 5 inches to gain clearence to unbolt the oil pump and remove the 7 qt. pan. It may have been possible to just remove the hi hump(if I had one) and raise the rans high enough to get the pan off. I think sometimes you just can't beat the engineering of GM.
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
Try spinnin 4 rear tars
Re: just to add more info on "Hi Hump" vs" Low Hump' trans covers
Great
![]() I'm looking at doing a 454/4L80E on my low hump.
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
Watch out for your cornhole !
![]() Join Date: Jun 2003
In the past, I've built two big block trucks with low hump cabs. Both of them worked fine as long as I had nice new cab mounts. 40 year old saggy cab mounts always let the cab rub the transmission. Some fresh ones and you had enough clearance to pass your hand between the cab and trans.
Never-the-less, changing a big block pan gasket brings the suck no matter which cab you have. I did rod and main bearings, oil pump and pan gasket on my 454 dually welding rig last summer and sprung for the nice Felpro one piece gasket and it made the job so much easier. Still, sucked though.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 01-16-2011 at 04:19 PM. |
its all about the +6 inches
brings the suck... LMAO!!!!!!
one million points for kevin! |
Kind of off topic but just to be sure if I get a new carpet for my truck I need a high hump carpet? Factory 400 big block auto.
You're not old, it IS loud! 1970 CST-10 BB 400 ![]() |
I agree with the 100 points! nothin better than "Big the suck"
![]() haven't heard anything like that since the army ![]()
-1969 C/10 Short Step soon to be Brand NEW Ls6/T56 ![]() -03 Mazda Protege 5 -WTB 1970 Chevelle project |
![]() Join Date: Dec 2003
haha.. i was thinking the same thing.. lol...
https://www.ebay.com/itm/295742064443 |
6>8 Plugless........
![]() Join Date: Sep 2007
Yes you will need a high hump carpet kit.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#10 | |
