![]() Join Date: Sep 2010
Will I Need New Adjuster Sleeves?
I'm putting 73-87 modular spindles on my 71 project. I've also purchased the 73-87 outer tie rod ends. My question is whether or not the 73-87 outer tie rod ends will thread in to the factory 71 adjuster sleeves on the tie rod or will I need to buy some sort of adapter sleeve? Is anyone else running this setup and are there any other changes I'll need to make for the 73-87 spindles (besides upper ball joints)?
Jay 1956 Chevy 210 Sedan 1970 Camaro Z-28/RS 1970 Chevelle SS 396 (numbers matching L34 car) 1971 Chevy SWB Fleetside with 1967 front clip - in progress My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=438156 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Will I Need New Adjuster Sleeves?
Jay,... the 71-72 tie rods and 73-87 tie rods are both 11/16" diameter.
So your 73-87 outers will connect fine to the 71-72 inners. (the 67-70 trucks have 5/8" tie rods) I really hate the looks of the oem tie rod connectors. I use a threaded connector from Edelbrock. (You can also get them from CPP, or PerformanceOnLine). They are a very nice piece. Your 71-72 upper ball joints need to be changed to the 73-87 version. The lowers are the same part form 71-87.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-16-2011 at 07:16 PM. |
Thanks for the info Keith. I don't like the look of the stock tie rod connectors either so I definitely plan on changing that.
I have a pair I never used that I will let you have for $40- they are exactly as pictured in post above. I can take pictures if interested. Harold
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
