Old 01-16-2011, 03:35 PM   #1
RaTcheTmasTer
Automania
RaTcheTmasTer's Avatar
How do you remove the lower radiator brackets??
I was looking at some on a 72 in a wrecking yard and can not see how these come off the radiator core support? are they riveted on? IF so, how do you get them off? drill or??
thanks
RaTcheTmasTer is offline   Reply With Quote
Old 01-16-2011, 04:13 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: How do you remove the lower radiator brackets??
Yes, drill the rivets.
Old 01-16-2011, 04:27 PM   #3
capev86
on my 72 burb c20 it was spot welds. i cut them off with a sawzall, drilled a hole and mounted the larger mounts for my 4 core swap. the right wheel well and radiator support have some decay due to a battery leak before i bought my truck. will do it nice when i replace those damaged parts as part of a minor touch ups.
capev86 is offline   Reply With Quote
Old 01-16-2011, 05:11 PM   #4
RaTcheTmasTer
Automania
Thanks guys for the quick reply. I will break out the drill and get them out.
