Starting problem
For some reason I have problems starting my truck if say I go somewhere like the gas station or store and the truck is turned off for only 5 minutes or so. It turns over but won't start right away. It will eventually start after several tries. If the truck sits for only a minute or less or 10 minutes or more it doesn't have any problem starting up though...just if it sits for around 5 minutes. It has been doing this for at least a year and I'm not sure what's causing it. The motor is a GM Goodwrench 350 (hasn't been modified), the carb is an Edelbrock 600cfm with electric choke, and it has the matching Edelbrock mechanical fuel pump. Any help would be appreciated.
its all about the +6 inches
Re: Starting problem
its your carb
This is one of the few things I dislike about the AFB carbs. A plastic carb spacer will help |
Active Member
![]() Join Date: Jul 2007
You may have a flooding problem. As you describ it: after a minute or so enough fuel leaks inside to flood it and after 5 minutes or so it has enough time to evaporate.
After you park take the breather off and look inside the carb throat with a flash light. Check to see if it's leaking fuel inside or if there's a strong smell of fuel. |
