01-16-2011, 09:05 PM | #1 |
Help! Fuel Tank Replacement
Need some advise. I just bought a new replacement steel fuel tank and the filler tube is shorter how or what do I do?
Old New
1970 Jimmy 4x4 IL6 1971 Jimmy 4x4 350ci v8 1971 SWB 327ci v8 1972 Short Stepside 305ci v8 1972 Blazer 2WD CST LS9 350ci 4sp 1999 4 Door LB 1 Ton Old Body Style 5.7 v8 |
01-16-2011, 09:42 PM | #2 |
Re: Help! Fuel Tank Replacement
Take them both to a radiator shop. The old neck is soldered to the tank and is easy to get off, but the new short neck is practically welded on. My rad shop found out that he couldn't unbolt the new neck because those little nuts wouldn't come off, so he broke the neck free from the flange and soldered the old neck to the new tank/flange.
This might help you, too: http://67-72chevytrucks.com/vboard/s...d.php?t=212828 |
01-16-2011, 10:37 PM | #3 |
Thanks, I guess a radiator shop is my next stop.
01-17-2011, 03:52 AM | #4 |
I've got a plastic reproduction tank in my 71. The big inlet is just like your new one, short. So I have the steel downspout running to just below the bedfloor, then a rubber hose from there across the frame rail, to that short tank inlet. Works fine.
Erik |
01-17-2011, 03:54 PM | #5 |
I cut the neck off the old tank and use it along with rubber hose to connect too the filler... rubber,metal,rubber...done deal!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
01-17-2011, 04:15 PM | #6 |
X2 this works great and its cheap!
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
