01-16-2011, 10:21 PM | #1 |
what should I offer for rolling chassis
I have a chnace to pick up a 2wd rolling chassis with typical rust no rot. The guy said make an offer what should I offer
Posted via Mobile Device |
01-16-2011, 10:22 PM | #2 |
Happy to be here
Re: what should I offer for rolling chassis
Offer 100.00, but go as high as 300.00 if you really need it. What are you after, the frame, suspension, or all of it?
01-16-2011, 10:25 PM | #3 |
Is it 5 lug with disk brakes? If so, I've seen people asking upwards of $500.00 dollars for them. I tried to sell one a year ago and was only asking $100.00 and couldn't get rid of it. I'd start with $100.00 offer and see where it goes.
-Scott- |
01-17-2011, 10:33 AM | #4 |
N2trux Looking for all of it i was thinking of $100 my self.
SJarrett I have to call the guy this evening and talk with him. Thanks guys |
01-17-2011, 11:40 AM | #5 |
100 bucks sounds like a good starting point. if its a 5 lug will be worth more just for the disc brake parts and 5 lug rear. check and make sure the frame horns are straight. let us know what you find.
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
01-17-2011, 11:57 AM | #6 |
tell him since ge's a nice guy you wouln't charge him to dispose of it for him
01-17-2011, 12:13 PM | #7 |
hahaha good point!
01-17-2011, 12:34 PM | #8 | |
Good luck with your purchase, if I found a local frame with no rot for $100 I would jump on it!
Trevor "You already said spite" |
01-17-2011, 09:52 PM | #9 |
He sent me some pictures what do you guys think? It appears to be 8 lug hubs
01-17-2011, 09:53 PM | #10 |
also does this look like a long bed frame to you?
01-17-2011, 09:59 PM | #11 |
For sure a long bed!!
72 Cheyenne Super 80 Silverado Blazer 2wd |
01-17-2011, 10:04 PM | #12 |
Happy to be here
Looks a like a C20 frame so it is defiantly a LWB.
01-17-2011, 10:13 PM | #13 |
What do you guys think its worth ? How big of a problem is 8 lug ?
01-17-2011, 10:25 PM | #14 |
HMM!! LWB, 8 lug. Last week scrap was $170 a ton here.
01-17-2011, 10:38 PM | #15 |
Vintage 4x4s
Nothing wrong with 8 lug...I think they actually made some that way on purpose. It is nice if you want to use it as a truck. Just make sure its not bent
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
01-18-2011, 11:47 AM | #16 |
Two things how much of a pain in the ass would it be to change it to 5 lug. Also how do you go about figuring if it is bent or not
01-18-2011, 12:13 PM | #17 |
If you want to have five lug truck that setup isn't worth a whole lot to you except the frame looks pretty decent. Basically you would be buying a bare frame with front and rear suspension and axle that you would have to take off and install five lug stuff.
If you did want to go 8 lug it might be a pretty decent base for a truck but unless a guy is towing or hauling loads on a regular basis 8 lugs aren't too popular with the custom truck boys and girls. Not a big pain in the ass to swap to five lug but you still have to go find a five lug front crossmember and suspension and five lug rear axle and springs. Then it is get busy an unbolt and bolt back on after the frame is cleaned up. If you want it to be a short bed you will have to shorten the frame the required amount. again not impossible as guys here on the board do it all the time but one more thing to do and get right before you go to the next step. I'd say offer $100 with the cash in your hand at the time if you want it. Let him see the cash when you make the offer. That is probably just about what the whole chassis would bring for scrap metal. Then you might be able to sell the rear axle depending on what it is. I bought a similar axle with 3.54 gears and Posi for 150.00 last year and if it is in decent shape someone will probably buy it if you post it on craigslist along with the hubs and rotors if they are good. You sell what you don't want to buy what you want in these deals. Last edited by mr48chev; 01-18-2011 at 12:17 PM. |
01-18-2011, 12:28 PM | #18 |
Mr 48 I really appreciate it
01-18-2011, 02:27 PM | #19 |
I might be wrong, but I think a 3/4 ton frame is actually thicker and more heavy duty that a 1/2 ton. I have heard they look the same but that they are thicker. Maybe someone who knows for sure will chime in.
