Old 01-17-2011, 12:37 AM   #1
slosteve
Rear Axle Seal
The first time that I had the right rear axle seal fail was in '08. When I pulled the axles, I found wear on them so I bought new Moser axles, bearings & seals. That seal lasted less than 5000 miles so I replaced it again, making sure that I got it installed flush with the end of the axle tube as I thought that must have been the cause of the failure. Now that seal is also leaking!
I did a search and found a couple of good suggestions; make sure that the vent is not plugged (although it is only one seal that is the problem) and buy a genuine Chev seal from a dealer, which is my next step.
Any body else had this situation?
slosteve is offline   Reply With Quote
Old 01-17-2011, 12:46 AM   #2
mwilliams5891
Re: Rear Axle Seal
just a quick question is it had to change the seals? a brake place wanted about 150 to do mine.
sorry not trying to steal the thread
-1969 C/10 Short Step soon to be Brand NEW Ls6/T56
-03 Mazda Protege 5
-WTB 1970 Chevelle project
mwilliams5891 is offline   Reply With Quote
Old 01-17-2011, 12:46 AM   #3
Tmend
Tmend's Avatar
Re: Rear Axle Seal
Might be rare but since u did find wear on the axles and the seal keeps leaking u might have a bent diff tube axle housing. If bent with in time the bearing will wear and then cause play therefor wearing out the seal and causing it to leak.
Tmend is offline   Reply With Quote
Old 01-17-2011, 01:11 AM   #4
slosteve
Re: Rear Axle Seal
Not if you have the tools. Use your search; there's some good threads on doing them.
Old 01-17-2011, 02:42 AM   #5
mwilliams5891
Re: Rear Axle Seal
ok thanks man
-03 Mazda Protege 5
Old 01-17-2011, 02:44 AM   #6
jrdv
jrdv's Avatar
Re: Rear Axle Seal
I had this happen on my 72 blazer. I ended up buying another rearend from the junkyard. Fixed my leak!
jrdv is offline   Reply With Quote
Old 01-17-2011, 01:26 PM   #7
slosteve
Re: Rear Axle Seal
If I hadn't been driving this truck since it was new, I might be more inclined to suspect it as possibly being bent. The seal that I replaced in '08 was only the second one in 37 years; the first was when I had the ring & pinion changed (for a different ratio) and subsequently all seals replaced.
Old 01-17-2011, 01:40 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Re: Rear Axle Seal
Take a look at my build thread below...I have pics showing the process of changing the axle seals as well as the pinion seal. Very easy job. Hope this helps.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-02-2011, 10:01 PM   #9
slosteve
Re: Rear Axle Seal
The Chevy dealer in my area says the factory seal is no longer available. So I went to Napa as the seal they sell is a Chicago Rawhide(?) and appeared to be a good one although made in Mexico.
Installed it and it lasted about 400 miles - I've got a problem.
While I was replacing it I had a friend looking over my shoulder who was a dealer mechanic (mostly GM) most of his working life and neither of us could see an 'obvious' problem. Axle fits snug in the bearing, no wear on axle, etc.,.
Old 02-02-2011, 10:33 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Rear Axle Seal
You seem like you're well aware of how to change the seal so I'd rule out installer error as the cause.
So, that leaves a part issue as the cause.
I think I'd buy yet another seal and a new axle bearing (Timken quality), then while installing them, I'd swap axles left to right. That way if it fails again you can rule out the axle as the cause.
