Old 01-17-2011, 12:52 AM   #1
198ChevyGuy
Exclamation HELP ok im a blue name now you can reply 78 big ten no start
OK to start i had to repair my tank it was in its church clothes and holy. Did that reinstalled and went to turn it over and nothing cam out line to carb, replaced fuel pump i could pump it by hand. tried again barely got anything. There is gas in the tank, Replaced the sock on my sending unit, still nothing trying prime it i ran gas down the lines, cranked it and checked the lines.... Nothing, checked the fuel filter, it was dirty replaced it, tried cranking it over still no gas . Tank is sealed pump is pumping, But no fuel through the pump, I need advice i have to have the truck running by tomorrow night. HELP LIKE MAJOR. and it has spark and will run when starting fluid is used, trust me ive used a few cans
198ChevyGuy is offline   Reply With Quote
Old 01-17-2011, 01:21 AM   #2
198ChevyGuy
Re: HALP ok im a blue name now you can reply 78 big ten no start
Not all at once now . Im serious i been working on this all weekend and have a limited budget. I really need some advice, I not used to chevy's I know toyotas and lexus. By trade. I could really use some help. I have to move tomorrow night, and have no running vehicle. I got a 84 celica with trashed crank, and my 78 c 10 Big ten 350 quadrajet if that helps. Its mechanical pump, And its craving life.
Old 01-17-2011, 01:29 AM   #3
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
How much gas is in the tank? Try pouring a little gas down the carb to help it get going. They can take a little while to prime if the lines are completely empty. Do you have someone to crank it over and keep it running while you are poring (tiny) bits of gas down the carb?
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 01-17-2011, 01:33 AM   #4
AceX
>130dB Moderator
AceX's Avatar
Tank switching valve. Located on the pasengers side, behind the fuel tank I believe.
Also, Try and give us more than 30mins before you say something about no one giving you an answer.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 01-17-2011, 01:35 AM   #5
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Oh yeah I was going to ask if you have dual tanks because that might be your problem.
Tony
Old 01-17-2011, 01:42 AM   #6
198ChevyGuy
I have one tank passenger side, Sorry its just me here, sadly i live in a city where i know no-one and. I feel like no-one knows how to turn a key. I got a bit impatient All the staring fluid fumes. And theres 3 gallons in the tank. Would be more but its a 4 mile walk to the gas station, and they only had a one gallon gas can. was alot of walking today.
Old 01-17-2011, 01:46 AM   #7
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Will it fire up at all with gas or starting fluid?
Tony
Old 01-17-2011, 01:47 AM   #8
198ChevyGuy
oh yeah till the can is empty. and it purs too
Old 01-17-2011, 01:54 AM   #9
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
If you have all the lines hooked up to the sending unit correctly it should eventually get prime to the carb. If all else fails just run a rubber hose from the fuel pump down into a small gas can.
Tony
Old 01-17-2011, 01:55 AM   #10
AceX
>130dB Moderator
AceX's Avatar
Single tank huh... hmmm... So nothing is getting to the carb at all?
Living Life @ 130dB
RIP El Jay
Old 01-17-2011, 01:59 AM   #11
198ChevyGuy
Nothing at all Makes me have a sad face. Its been a frustrating few days.I've replaced everything except the carb and fuel lines it seems. even that annoying pain to find lil hose of the filler. I worked on it tonight till i couldnt feel my toes anymore (due to the cold).
Old 01-17-2011, 02:11 AM   #12
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Did you make sure to connect all the fuel lines on the sending unit and fuel pump correctly, and did you removed the push rod for the fuel pump when you replaced it?
Tony
Old 01-17-2011, 02:11 AM   #13
198ChevyGuy
wow 85 you have 663 posts still in pink, i got solicited after 30
Old 01-17-2011, 02:23 AM   #14
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Alright well im going to bed since you don't feel like answering simple questions when someone is trying to HALP you.
Tony
Old 01-17-2011, 02:28 AM   #15
198ChevyGuy
push rod? i made sure it was in the up position if thats what you mean. made sure it was aligned when i tightened it down
Old 01-17-2011, 02:32 AM   #16
198ChevyGuy
but no i never removed the pushrod. i guess i did it the hard way and held it in place with a magnet
Old 01-17-2011, 02:35 AM   #17
AceX
>130dB Moderator
AceX's Avatar
I'm at a total loss honestly. Other than the puchrod not moving at all, I can't think of anything else.
Can you smell fuel at all when trying to start it?
Living Life @ 130dB
RIP El Jay
Old 01-17-2011, 02:39 AM   #18
198ChevyGuy
i can smell starting fluid lol.
since i sealed the tank i dont smell any gasoline
Old 01-17-2011, 03:56 AM   #19
cvalcore
cvalcore's Avatar
i no you said you changed the fuel filter but have you checked the little filter that is in the fuel inlet on the carb if you unbolt the fuel line from the carb there is a little filter in there that can get pluged up some times. if its the stock carburator un less this is the filter you changed i no a lot of these older trucks have a inline filter thats been added over the years.
cvalcore is offline   Reply With Quote
Old 01-17-2011, 04:47 AM   #20
198ChevyGuy
I have one ordered for my truck. Its basicly stock besides the th-700r4. I checked that first. it will be in friday, There wasnt one there and didnt look to be one there for a very long time.
Old 01-17-2011, 05:00 AM   #21
cvalcore
cvalcore's Avatar
ok are you getting fuel to that point?
Old 01-17-2011, 09:40 AM   #22
truckdude239
truckdude239's Avatar
Do you have a vented gas cap on it?or is it totally sealed i think you got tyhe line ont eh tank backwards
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-17-2011, 08:16 PM   #23
198ChevyGuy
Re: HELP ok im a blue name now you can reply 78 big ten no start
I only have sealed tank, and i have the lines right, with one being the threaded and one being just hose and clamp you cant get it wrong. and the gas cap on it is ancient so i doubt that its sealed. but i tell ya if i blow into the tank from the fuel filter it blows back at me so im thinking i might need more gas in it. Considering im not getting the Capri Sun effect.
Old 01-17-2011, 09:02 PM   #24
customizer76
You maybe getting the Capri Sun effect but I fear you have a line with a hole in it. I had one do this to me and had to replace the line from the tank to the pump and the truck fired right up after the first shot of fuel down the carb.
customizer76 is offline   Reply With Quote
Old 01-17-2011, 09:04 PM   #25
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Hi I am one of the moderators for this section. I am intrigued by your statement that you were solicited to become a member here. I would like to know who told you you HAD to become a member here. Membership on this site is strictly voluntary. The administration here does require a membership if you want to pose whats it worth questions about your truck or you wish to sell items in our classifieds.We demand membership of noone .In addition we have many professional mechanics and even a former GM truck plant guy who designed and built these very trucks here who are not subscribing members here who are liked and respected here who have never been asked to subscribe unless they wanted to post a for sale thread or a whats it worth thread pertaining to their own truck..
I am also going to mention to you that while I can understand the fustration of not being able to make your truck run , particularly while on a deadline of any kind can be fustrating, comments like the above and the one about "not all at once" especially with the title of the thread makes those who do have knowledge to help you feel slighted and then they tend not to reply.
As a member here who appears to have joined within the last month, i hope this constructive criticism helps you with your relations here, and as always should you have any questions or concerns, please feel free to PM myself or any of the other staff here.
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
