Old 01-17-2011, 03:10 AM   #1
BadaSs_Cal
BadaSs_Cal's Avatar
SM 420 Transmission
Was the down to the left reverse exclusive to only these transmissions? If not, what else could it be?
I love how it shifts, doesnt go anywhere fast, but its super fun having those close of gears.
P.S. I never use 1st (low) gear I just start at 2nd, I wont wear the trans out any faster will I?
66 Gmc 1 ton. Long Step 351e V6
69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil
61 Shortbed Fleetside 1/2 ton.. in progress
Next a 50-53!
MY BUILD THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=447926
BadaSs_Cal is offline   Reply With Quote
Old 01-17-2011, 08:18 AM   #2
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: SM 420 Transmission
The reverse on the 420 was different than the 465. If you're not going to use it, you might be able to sell it to the Jeep guys - they love 'em.
If it's a '67 (last year) it was the only year with an integrated reverse light switch.
These guys have a lot of info - including some pics:
http://www.novak-adapt.com/knowledge/sm420.htm
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 01-17-2011, 04:11 PM   #3
BadaSs_Cal
BadaSs_Cal's Avatar
thanks.
Next a 50-53!
MY BUILD THREAD
Old 01-17-2011, 04:24 PM   #4
treveiger
treveiger's Avatar
Its a sm420, i have a sm465 and i always use 2nd gear for take off unless im in a parking lot or want to screw around. I think they made second gear for normal take off and first gear for when its pulling heavy loads so i cant see it hurting taking off in second. These trannys are bullet proof. I was thinking about switching my 465 out until i decided i really liked it and wanted to keep it, i think its a blast shifting those close gears, even though its not super fast its still a lot of fun. Do you have any plans for it? Im planning on getting mine rebuilt next summer because i just want it like new when i make my truck a DD.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 01-17-2011, 10:31 PM   #5
BadaSs_Cal
BadaSs_Cal's Avatar
My trucks going to be a DD. the only mods I have planned is goin 5 lug, going SWB, and moving the tank. Other then that I love my 250 and 4 speed. Are you going to try and rebuild it yourself or take it to a shop? I thought about tackling it, but Im in the middle of my 250, would be nice to have both done at the same time.
Next a 50-53!
MY BUILD THREAD
Old 01-17-2011, 11:23 PM   #6
NORMSCOLORADO
NORMSCOLORADO's Avatar
i have a 420 in my 67 one ton with the reverse light switch this tranny had the ever loving **** beat out of it for 190 k and still works perfect! i was going to throw a nv3500 behind the 6.5 td but this one will NEVER break i just gotta find a higher speedo gear for it.....
04 Chevy Colorado Z71 4X4
76 Chevy C-10 Custom Deluxe (sold)
67 Chevy C-30 1 Ton 9' stepper 6.5 Turbo Diesel
NORMSCOLORADO is offline   Reply With Quote
Old 01-18-2011, 01:58 AM   #7
BadaSs_Cal
BadaSs_Cal's Avatar
higher speedo gear?
Next a 50-53!
MY BUILD THREAD
Old 01-18-2011, 02:18 AM   #8
treveiger
treveiger's Avatar
Im converting mine to 5 lug to but im defenitally keeping it long because i like having extra room and want to put a bench seat in the back. I want to try building it myself but ive been worried about it because of people telling me its a pain but ive also heard its easy , it shifts fine but leaks and its starting to drive me crazy. I wish i could know for sure the diffculty of rebuilding it because i think itd be cheaper, a shop said theyd look at it for me for $70 to tell me how much itd cost so i thought i might do that. I know what you mean you want the tranny done when i finish resealing the motor and getting new heads id like to be able to finish it and not have to wait on the tranny
Old 01-18-2011, 07:10 PM   #9
NORMSCOLORADO
Originally Posted by BadaSs_Cal View Post
higher speedo gear?
yeah i have a 14 bolt full floater out of a 84 gmc c 3500 under the back of the 67. my speedo gear was set up for 514's and now its gunna have 373's but the closest i can get is 410 speedometer gear unless anyone knows of a better way?????? cuz my speedo is gunna be like 15-20 mph off lol
Old 01-18-2011, 07:55 PM   #10
jakeblues652
jakeblues652's Avatar
nice piece of useless info about the sm420..first gear is not syncro'd, so it could possibly grind when shifting. i can start in first and when shifting to second, it only grinds on occasion. but normally second is where to start.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 01-18-2011, 11:52 PM   #11
treveiger
treveiger's Avatar
My 465 doesnt grind when shifting into 2nd from 1st unless i do something like drop the clutch an floor it then try to put it in 2nd but it wont shift into 1st until im completely stopped. I wish is was syncro`d thatd be awesome!!!
Old 01-19-2011, 12:09 AM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I drove a Gama Goat when I was in the Army guard unit here. It had an SM420 in it and was a buncha fun. So was the '56 SWB Chevy 1/2-ton I had back in '74. It originally had a 3-speed, but the guy I traded a '55 150 2-dr sedan for it, had put the 4-speed in it and couldn't afford to have a driveshaft made.
I usually started off in 2nd gear. No problemo. 1st was definately not synchronized.
Member Nr. 2770
