01-17-2011, 09:43 AM | #1 |
Retired Air Force Veteran
WIW: 6cyl A/C
WIW: Trying to find out what a complete 6cyl A/C setup is worth
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
01-17-2011, 03:00 PM | #2 |
Re: WIW: 6cyl A/C
ttt
01-17-2011, 03:26 PM | #3 |
Re: WIW: 6cyl A/C
Allot!!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
01-17-2011, 03:32 PM | #4 |
C10 addict
Re: WIW: 6cyl A/C
Is it for a 250 or 292? (not sure if they are different) Do you have all the brackets and pulleys? If so, is it the 2 groove water pump and harmonic balancer pulleys or the 3 goove pulleys? Is it still installed on the motor?
01-17-2011, 03:46 PM | #5 |
Re: WIW: 6cyl A/C
Not sure of the motor size. It was quickly pulled, sold and replaced with a big block. The pulleys went with the motor but all of the brackets are there. I can get pictures around 6pm and I'll post them. The parts are out and ready to ship
01-17-2011, 03:58 PM | #6 |
C10 addict
Re: WIW: 6cyl A/C
The correct pulleys are the hardest part to get from my experience, especially the crank pulley because it's the harmonic damper as well, but I'm sure it's still worth something. I'd be interested in seeing pictures to compare to my 292 A/C setup.
01-17-2011, 04:12 PM | #7 |
Re: WIW: 6cyl A/C
I'll have pictures in a few hours. I'll PM you. Thanks, Harry
