C35 Crew Dually
84 1 ton dually
Called the parts store to price
Lower ball joints,upper ball joint,tie rods,adjustment sleeves,bearings ETC For when i lower my truck. none the less big $$$$ lol But they are telling me the upper ball joints only come with control arms and can not be bought just the ball joints.is this true? that's over 600 for just 2 parts! I hope there's another way around this :S
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
C35 Crew Dually
Re: 84 1 ton dually
Sorry I posted be for i looked further i can buy them separate thanks
Getting Old; Going Broke
Re: 84 1 ton dually
Find a new parts store?
*edit* You snuck a post in while I was looking it up. ![]()
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. Last edited by RandyP; 01-17-2011 at 12:27 PM. |
C35 Crew Dually
Re: 84 1 ton dually
Well since this is a new thread an i can't post doubles. i might as well use it.
My truck has been severely raped in the wiring department After lots of reading and lots of tracing i have found out why my gas gauge is not working...the gauge cluster wire was going to the pass side of the carb? IDK what someone was thinking but when i unhooked it from the the carb. the gauge went from empty to way past full. so i decided to temporarily hook it back up to the tanks sending unit to see if it would read.... but it doesn't move. (now that I'm posting this and thinking about it my temporary wire i was using is a far thicker gauge of wire would that make a difference? ) or is my sending unit bad or have a bad ground?
#5 | |
C35 Crew Dually
Re: 84 1 ton dually
