Old 01-17-2011, 01:28 PM   #1
Miller92
Miller92's Avatar
Anybody got a truck on stock suspension with big tires?
I want my truck to sit higher than stock height, but don't wanna put a lift on it, so I was thinking about just putting some bigger tires on it. So if anybody has a truck with big tires I'd love to see it.
Miller92 is offline   Reply With Quote
Old 01-17-2011, 02:48 PM   #2
TwoFiftyShifter
Re: Anybody got a truck on stock suspension with big tires?
Without modification, I think 31x10.50-15 is the largest you can fit in the rear, not sure if you can fit it up front. Also, we have no clue if you have a 1/2 ton or 3/4 ton, 2wd or 4wd, and they do actually sit at different heights and thats a necessary peice of info to get the right answer.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 01-17-2011, 02:55 PM   #3
Miller92
Miller92's Avatar
My bad guys, for some reason I always forget that info. I've got a 1/2 ton LWB/fleetside 2wd.
Old 01-18-2011, 05:05 AM   #4
blackedoutharley
"here is my '65 LWB 2wd with 15"X8" wheels and 31x10.50R15 tires all the way around...
blackedoutharley is offline   Reply With Quote
Old 01-18-2011, 12:40 PM   #5
tenni126
I can't find any pics right now, but before I painted mine up I had 32's on the back, and 31 10.5's on the front, cause it's what I had available at the time. Don't remember any issues with rubbing. BUT, you want to make sure you have all as it should be with suspension. Sat just like blackedoutharley's once I put fresh, stock height springs on it.
tenni126 is offline   Reply With Quote
Old 01-18-2011, 05:28 PM   #6
Miller92
Miller92's Avatar
Good looking truck harley. Thanks for all the help guys.
Old 01-18-2011, 05:29 PM   #7
Miller92
Miller92's Avatar
Hey Harley, any idea how much you get to the gallon with them on it?
Old 01-18-2011, 05:49 PM   #8
allengator
allengator's Avatar
sharp !
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 01-18-2011, 06:08 PM   #9
tenni126
I can tell you that mine got waay worse after I put regular street tires on, due to the steep rear gears I had. But, that's what the overdrive swap was for.
Now, all is well.
It went from around 13-14, down to about 10. Now, back up to almost 17-18.
Old 01-18-2011, 06:20 PM   #10
Miller92
Miller92's Avatar
Well I'm putting a late model motor and tranny in mine. It's just a 350 with a 700r4, which has overdrive, so I know that'll help, but I know the rearend makes a difference too.
Old 01-18-2011, 06:43 PM   #11
Heater63
Heater63's Avatar
Check out lakeroadster and his rear tires (and trick widened bed).
292 + TKO500
Heater63 is offline   Reply With Quote
Old 01-18-2011, 08:47 PM   #12
blackedoutharley
Originally Posted by allengator View Post
sharp !
Thanks guys... the pictures do it a lot of justice... it is rough after years of neglect.
I have 3.42 gears with a SM420 trans and it gets about 13-15 on the freeway @ 70mph +/-. It has been many years since it was my daily driver so I might be off a bit.
The biggest benefit (to me at least) is that it is a true truck tire and able to carry a load. The height also helps fill the fenderwells without lowering (and helps with gear ratio) and because of the tall sidewall it rides very nice.
