Old 01-17-2011, 03:44 PM   #1
Gene
Gene's Avatar
NP205 shift rod questions?
Is this the position for 2wd? I try to find 4 positions for this case but it seems like it only has 3 and going from 4wd to 2wd the closest rod stays put but the farthest one goes in half stroke? Can snyone show me where these rods should be for the 2wd position?
Gene is offline   Reply With Quote
Old 01-17-2011, 03:57 PM   #2
Gene
Gene's Avatar
Re: NP205 shift rod questions?
Ok, I found an answer(I think) The closer shift rod controls the rear output and the farthert controls the front, so mine in the picture above should be rear engaged and front neutral right? So my question now is, how can I adjust my linkage where I get a positive shift from 4wd to 2wd? It wants to pull both rods into neutral, and the only way it will slide into 2wd is if I ease from neutral to 2wd?
Old 01-18-2011, 10:20 AM   #3
monza1979
monza1979's Avatar
that appears to be the correct shift pattern diagram, my guess is that your detent rods are just worn out (Shift rods) and need replacing. not sure where to find factory units, but if it is an offroad vehicle you may want to check out JKWoffroad.com's twinstick conversion. thats the product i will be running come tax return time!!
I had the right to remain silent, but i didn't have the ability!
78 chevy swb 4x4 sm465 np205 350 4" lift, ORD flip kit, ORD Ext. brake lines
79 Chevy Monza:current plans, dz 302, 4 speed
69 Pontiac Firebird: 74 s.d. 455 build up, m22 rock crusher
monza1979 is offline   Reply With Quote
Old 01-18-2011, 03:35 PM   #4
csb#356
In the picture you posted thats 2 hi. There is no way to adjust the linkage on these cases. I'm not really understanding what your problem is. When You try and pull the lever all the way back into 4 hi it puts the rear output into neutral also?
csb#356 is offline   Reply With Quote
Old 01-18-2011, 05:56 PM   #5
Gene
Gene's Avatar
No, it goes into 4 hi with no problem. It's going from 4 hi to 2 hi that it wants to pull both rods into neutral?
Old 01-18-2011, 06:56 PM   #6
csb#356
If the rear shift rod has just a little play when going into 2wd I wouldn't worry unless It actually shifts into neutral. Is the transfer case in the truck.
Old 01-19-2011, 05:04 AM   #7
1malo68
1malo68's Avatar
If you think you need new shift rails, just send me a PM with an address and I'll send you my old ones in a flat rate box. I don't need 'em anymore. They worked real well in my case but I went with the ORD shift rails and twin sticks. Don't worry about paying for shipping. Just glad to help out.
Dan
1malo68 is offline   Reply With Quote
Old 01-19-2011, 05:50 PM   #8
Gene
Gene's Avatar
Dan
Thanks Dan, so are you talking about the rods that go into the case, or the actual rail that the shifter attatches to? I dont see any play or wear in mine is the only deal, it's all real tight and my transfer case came from a low mileage truck?
Old 01-19-2011, 06:03 PM   #9
1malo68
1malo68's Avatar
I'm talking about the rods, but I think I still have the link beween them too
Old 01-19-2011, 06:46 PM   #10
Gene
Gene's Avatar
Yes, but it's not on the road yet, maybe under power the shift will be more precise? I am just shifting the case to get an idea of where the position is for 2wd n and 4wd hi and lo.
Old 01-20-2011, 08:39 PM   #11
glimmertwin01
glimmertwin01's Avatar
Ok can someone post a pic or diagram of a stock 205 shift rod and linkage? Im considering buying a 80 K15 step but the T case shifter is absent i can see the rods coming out of the case but theres no rods or pivots..etc.. and its too showy to climb under my 72 and peek
thanks in advance
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 01-21-2011, 03:48 AM   #12
csb#356
I would betcha that once you get her in the truck with some drivelines on(which I think would lessen gear play a little) it will shift just fine. All the ones I've had have had play in them like that but always shift fine. But If it makes you feel better why not replace them for a good set. After all he said hes got a free set. But then I guess you've got to muscle it outta that truck.
Old 01-21-2011, 05:44 AM   #13
1malo68
1malo68's Avatar
thanks in advance
Here ya go!
