Old 01-17-2011, 04:16 PM   #1
Section8
TH350 Cooler Lines
Hey Everyone,
I'm taking care of a couple things on a 71' C10 I bought and one major issue(well it is to me) is the trans cooler lines are touching the exhaust. These things look like original hard lines that have been pretzeled through many years of use. They do run to an auxiliary cooler in front of the radiator and through the radiator as well. I know there has to be a better solution. I was thinking of running braided steel lines but cost is more important than appearance as this is only a work truck.Let me know what works and doesn't. Thanks!
Section8 is offline   Reply With Quote
Old 01-17-2011, 04:24 PM   #2
gonzo6869
Cops, ha, catch me if you can!
gonzo6869's Avatar
Re: TH350 Cooler Lines
I got the same thing going on, the cooler lines are right next to my pass. side header. I assume it can be replaced with some rubber line (away from any heat), but really don't know.
72 C-10 Stepper
350/TH350
3.73 in the back
Edelbrock intake and Carb
Hooker Comp Headers
275/60R15 on Rallies
gonzo6869 is offline   Reply With Quote
Old 01-17-2011, 04:29 PM   #3
Section8
I'm running the stock manifolds, can't imagine it with headers! Boiled tranny fluid anyone?!
Old 01-17-2011, 05:59 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
pull the lines away from the exhaust, and secure if needed, and call it done?
Old 01-17-2011, 06:58 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is the way some one did it. I saved the pictures to my hard drive.
You can see the lines run under the starter and along the oil pan. They are probably clamped to a pan bolt.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-17-2011, 08:35 PM   #6
Hubscrub
Cruzin
Hubscrub's Avatar
you can buy new hard lines or run the ones you have better. Keep in mind that you can't run just any "rubber" line. There is special rubber line for this and its much higher $ the last time i bought some but i run hard lines anytime i can.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 01-17-2011, 08:41 PM   #7
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
http://www.jegs.com/i/JEGS+Performan...60366/10002/-1
http://www.jegs.com/p/JEGS-Performan...61335/10002/-1
The 1st link is to a kit Jegs sells to make all the AN lines you need with Braided SST.
The second is the proflo hose that I used to build mine along with the Jegs fittings.
This, for me, works a ton better than hard lines - I was able to tuck them up into the frame rail and keep them out if the way, I like the black lines since they always look clean and the are kind of hidden
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 01-17-2011, 09:07 PM   #8
cparman
sharp as a marble
I have a pretty low opinion of the braided flex lines and rubber trans cooler lines. IF I WERE YOU, I would buy a new set of pre bent lines, and massage
them to clear what you want them to clear. When you get to the radiator I would figure out which one goes into the trans cooler in the radiator ( the top one, I think ) and run the fluid into the radiator, and out of the radiator and then trhut the external cooler and THEN back to the trans. Transmission fluid likes to be a very consistent temp., and this would do that.
Originally Posted by Section8 View Post
Hey Everyone,
cparman is offline   Reply With Quote
Old 01-17-2011, 10:29 PM   #9
Section8
Thanks a ton for all the feedback, pics and links!
