Old 01-17-2011, 09:29 PM   #1
barryvanhook
barryvanhook's Avatar
Shock relocation (?) with leaf springs
I have a ’69 “Chevy” truck .. at least that’s what the title says. But I believe the underside is all GMC of that year. The data plate carries a GMC vin and it has rear leaf springs. I'm uncertain of the identity of the rear end; it does have 5-bolt axles. The previous owner lowered the rear using a flip kit. The rear shocks (air) are leaning forward at a 45-degree angle, approximately. The springs each have 4 leafs. I don’t have much rear suspension travel. I know that those of you with rear coils use the shock relocation brackets from CPP or ECE, but they don't apply to rear leaf suspensions. What are my options to regain suspension travel?
Barry
Barry L. Van Hook
'69 Chevy Frankentruck
barryvanhook is offline   Reply With Quote
Old 01-17-2011, 10:20 PM   #2
72MARIO
72MARIO's Avatar
Re: Shock relocation (?) with leaf springs
Look at the factory shock brackets. There is a hole right behind the stock top stud back closer to the axel. Drill it out and bolt in a stock front upper shock mount. Cheep relocate kit.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-19-2011, 01:51 AM   #3
barryvanhook
Thanks much ... I'll check this out.
Barry
Barry L. Van Hook
