01-17-2011, 10:17 PM | #1 |
How much wight can it Tow ?
Just wondering how much weight my 68 Suburban should be able to pull with out over working it. It has a 327 T400 and 3:73. Looking at pulling a 4000lb camping trailer.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-17-2011, 10:21 PM | #2 |
Re: How much wight can it Tow ?
C10 or C20?
If it is a lot, I'd recommend air bag helpers since you are very low already, towing wise.
01-17-2011, 10:34 PM | #3 |
Sorry it`s a C10 I am going to put 2600 bags in the back in place of the stock coils.
01-17-2011, 10:49 PM | #4 |
Big Red - Now its a SWB!
I'm not sure what the limit is, but I think you could pull 4000 lbs just fine. Just make sure your cooling system is in good shape (clean coolant, right antifreeze mix, shroud in place, good fan clutch, 3 row or bigger radiator that's not plugged up, good thermostat, no leaks, etc.) and if you don't have a separate tranny cooler you might consider adding one. Also make sure your tranny filter and fluid and diff fluid are in good shape. Then enjoy the ride!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
01-18-2011, 12:22 AM | #5 |
"brand new second-hand"
consider a load leveling hitch to help spread the weight evenly to the front and rear axles...........
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
