Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-17-2011, 11:42 PM   #1
bitchin85
bitchin85's Avatar
household plug on a truck?
i have a small 1/2 horse 1 gallon air compressor that id like to mount inside my toolbox for airing up tires when off road and eventually running train horns and whatever else i need. what is all involved to wire it all in? i want to use a toggle inside the cab. can i just wire it direct to the battery with a fuse or???
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 01-18-2011, 12:57 AM   #2
Benelli
Watchin the rust grow
Benelli's Avatar
Re: household plug on a truck?
Truck stops should have a inverter you can just plug into your cig. lighter.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 01-18-2011, 12:59 AM   #3
vectorit
What?
vectorit's Avatar
http://www.arbusa.com/Products/Compressors/19.aspx
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 01-18-2011, 07:43 AM   #4
bitchin85
bitchin85's Avatar
can they be wired into the fusebox or battery? i want to make it more permanent then a cig lighter adapter
Originally Posted by vectorit View Post
this would be awesome if i had the funds.. my dad just had to move across the country for a job and he left me all of his tools and the compressor was among them so right now im in it for $0.00.
ill probably get the adapter. i just hope i can wire it in to the battery or fuse box.
Old 01-18-2011, 11:50 AM   #5
cable666guy
cable666guy's Avatar
Without seeing the inverter it's hard to say which way you could wire it up.
Compresors generally have big draws, you'll want to make sure your wires are big enough, and that you have the proper relays and such...Do more research, it's way to easy to burn your truck down.
cable666guy is offline   Reply With Quote
Old 01-18-2011, 01:26 PM   #6
panhandler62
Java Mechanic
panhandler62's Avatar
We have a small inverter connected directly to the battery on our RV so my wife can use her laptop while we're on the road.
I'm not sure how much your compressor draws. I have a portable 2g that draws 15.kw. You'll need at least a 2500kw inverter to run that. The inverter is going to run you about $230 (you may find slightly better deals here and there) and it will require a continous 200amp supply.
An inverter of that side has to be wired directly to the source because it, just like a big stereo amp, is far too big for existing circuits in the truck. That will work fine with the truck running but you would also need a couple of auxilary battaries to use it with the engine off.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
