Old 03-11-2003, 11:42 PM   #1
redgoatroper
auto to 4 speed
i have a 76 3/4 ton chevy pickup that has a bad t350 tranny in it with a full time transfer case, what i want to do is change it to a manual trans. The question i have is will a manual tranny bolt to the full time transfer case? or do i need a different transfer case?
redgoatroper is offline   Reply With Quote
Old 03-12-2003, 02:24 AM   #2
Pont
I need another Barley Pop
Pont's Avatar
I'm guessing you will need to change the transfer case as well. I'm not really educated on the NP203 but I'm thinking that the input spline on the t-case for an auto trans is different than that of a manual trans. At least this is the case with a NP205 part time t-case.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 03-12-2003, 06:18 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
1974 was the only year for SM465 and NP203 together. So you would need the adapter and check the input/output shafts. The SM465/NP205 combo should be easier to find.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
