01-18-2011, 12:14 AM | #1 |
turbo 400 kickdown
Anyone have any pics of where and how i should set one up? My trans shifts weak and really quick! its got a shift kit in it and is a low miles turbo 400 under 40k! everything was super clean when we opened it up! thinking the kickdown is the problem and even if it aint i want one anyways lol!
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
01-18-2011, 12:34 AM | #2 |
Re: turbo 400 kickdown
Here are a few pics. The Kick-Down Mounting Brackets are available at your local auto parts store. Sold under the Edelbrock brand #8036 Anodized, 8030 Chrome, 8031 & 8032 Black.
01-18-2011, 12:34 AM | #3 |
Its electric, I got one off a newer truck. I added the whole throttle assembly with switch mounted on it and cable throttle linkage.
70 Chevy SWB Fleet Project. 06 Lancer Evolution MR SE, stupid fast! 03 Ford f-250 crew cab, 6spd, diesel 56 ford f100 project My build thread. http://67-72chevytrucks.com/vboard/s...d.php?t=426739 |
01-18-2011, 12:45 AM | #4 |
Future TOTM Winner
Here are a couple pics from a stock 69 setup, don't know if that helps you much or not.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
01-18-2011, 12:52 AM | #5 |
so this thing need to be set at full throttle?
01-18-2011, 01:28 AM | #6 |
I thought the 400 Kickdown switch was on the carb from 70 and older trucks??? From 71 and newer they came off the gas pedal? Maybe i am dreaming????
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 01-18-2011 at 01:28 AM. |
01-18-2011, 03:59 AM | #7 |
When I ditched my old and worn stock q-jet on my '69 I replaced with a 600 cfm Edelbrock and they did not have a location for the stock kick down switch. I inquired about what I should do from Edelbrock and they said that they sell a WOT bracket and micro switch for their NOS setups and it would work fine. It was more than I wanted to spend for a anodized piece of aluminum and a $2 limit switch. Also I wanted the tranny to shift before WOT so I would not be wasting all kind of gas just trying to drop into gear. I went to the surplus store and bought what I needed for around $3 and made a kick down switch that fits in front of the throttle linkage and I can adjust it to open when ever I want to. I kind of rough wire it to see if it would work and it does just fine. Most of this is temporary because I am going to be installing a 700r4 here soon, so I did not want to get to technical over a short term fix. I did secure the wire a little better since the photo.
here is the original one that did not fit the new carb
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 Last edited by Mike Bradbury; 01-18-2011 at 04:02 AM. |
