Old 01-18-2011, 12:07 PM   #1
keanevann
Heater Wiring
Soooooo.... the previous owner installed an aftermarket heater and now I am trying to put a stock one back in..... I have the harness (1 plug for the resistor, 1 plug for the back of the controls, 1 plug for the blower motor, AND the mystery wire.... Im guessing it most likely going to go to a switched positive? Is this correct? Also, Is there no ground wire?? Thanks in advance guys....
keanevann is offline   Reply With Quote
Old 01-18-2011, 12:22 PM   #2
Gene
Gene's Avatar
Re: Heater Wiring
You should have a long orange and or pink wire that plugs into the fusebox. Is this the mystery wire?
Gene is offline   Reply With Quote
Old 01-18-2011, 12:32 PM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: Heater Wiring
If you are trying to go back to stock then what you have will not work. You should have a harness that has a 4 prong plug that has 3 wires that got to the resister and the (positive) brown wire under your dash will plug into that 4 prong plug also. (The brown wire gives power to the systom) Now the 3 other wires will go into a plug that leads to the resister, with one wire (orange) coming out of that plug leading to the heater motor. Then there is a short grounding wire that goes under one of the fans mounting screws to the one of the upper housing mounting screws. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
