03-12-2003, 12:20 AM | #1 |
Truck'n the alcan
What to do ?
Since the roads are good now I took a small road trip today. All was good untill I got up to about 70 mph and could feel a vibration. When I got home I checked the u-joints and carrier bearing and found two u-joints installed backwards but in good shape, but the pinion bearing has a lot of play. It's not leaking and it's topped off with lube but it has I would guess about 1/32 side to side play. I believe it's an HO72 but not 100% sure about that.
What should I do? Is this something I can fix myself and how? Or should I be looking for a new one?
68 GMC 4x4 71 C20 Custom Deluxe 83 1/2 ton conversion van |
03-12-2003, 01:52 AM | #2 |
I think thats kinda normal ...... go to a rear end shop and see what they can do. Are you sure it's not the wheels ? or drive shaft ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
03-12-2003, 02:43 AM | #3 |
It looks like you have the HO-72 Eaton rear, it has a round centersection and it looks like yours does too, Dana had funny shape characteristic of most all light-duty Dana axles
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
03-18-2003, 01:36 AM | #4 |
Born To Lose Club
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Hey Alaskan, got any pics of your Trucks you could post?
Brian Smith - "Born To Lose" 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada! - 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs - 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
03-18-2003, 06:09 AM | #5 | |
Truck'n the alcan
03-18-2003, 09:17 AM | #6 |
excuse my ignorance, but how do you install a u-joint backward?
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
03-18-2003, 11:53 AM | #7 |
Spank 'em if you got 'em!
Dido on the U-joint backwards!??
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
03-19-2003, 12:59 AM | #8 |
Truck'n the alcan
Well I thought that would raise a few eyebrows. I'll attempt to explain.
The type of u-joint thats in my truck is like the one pictured below with the grease zerk in the same location. If you look you'll notice that the zerk is offset to one side and is pointing to the side that it's offset. Generaly when I install u-joints of this type I will orientate the zerk to face the driveshaft and not the yoke. I do this because if it faces the yoke there often times is not enough room to get a standard grease gun fitting on the zerk. In short the zerk should be orientated to face the expansion of the joint and not away from it.
68 GMC 4x4 71 C20 Custom Deluxe 83 1/2 ton conversion van Last edited by Alaskan; 03-19-2003 at 01:04 AM. |
03-19-2003, 01:01 AM | #9 |
Truck'n the alcan
Forgot to add the pic.
03-19-2003, 01:16 AM | #10 |
Hey Alaskan...
This is sort of off the subject of your post but... I grew up there and had a few 67-72 trucks...in fact I had a 67 GMC short fleet side that was dark grey, lowered, with a 383 and posi. I sold it around 93 I think.....but on one of mys last trips to Anchorage, I stumbled onto it in Mountain View. It seems to be in reasonable condition...if i recall the metal and body were in very good condition...don't know now. Thought you might be interested....its in a neighborhood near the carwash there in MV...it shouldn't be hard to find. If you are interested...I can probably get you an address. I don't know who owns it. I attached a pic of it when I had it. Cheers...
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
03-19-2003, 01:45 AM | #11 |
My 71 4x4 did the same thing, I rotated the tires and tried again the problem went away. I then took it down and had the tires balanced. I think it made a difference, that i had an unbalanced tire on the front.
big red 71 |
03-19-2003, 01:55 AM | #12 |
Truck'n the alcan
The carwash is as far as I've been going in that area of town, been alot bad things happening there lately. The next time I go I'll look around for it.
As far as the play in the pinion and the vibration, the shops I've talked to locally have said the pinion play is not the problem. I got the wheels rebalanced with no change, one guy said a weak shock absorber could cause the vibration.
68 GMC 4x4 71 C20 Custom Deluxe 83 1/2 ton conversion van Last edited by Alaskan; 03-19-2003 at 02:03 AM. |
