Old 01-18-2011, 03:12 PM   #1
colinlx
colinlx's Avatar
Rear Axle Swap
Hi all, finally getting to do some more work on the truck this winter. I've looked around here but can't come up with the answer I'm looking for.
I've got a 3:73 posi rear axle out of a mid 80's chev truck that I'd like to throw into the '72. My '72 has coils, so the trailing arm perches should be easy to re-locate on the 3:73 axle. I'm having trouble figuring out what to do with the panhard or track bar. I'm not planning on lowering the truck, just going with the original stance. The guys at ECE tell me that their super track bar won't work for stock height. Anyone have any suggestions as to what I can do? I'm thinking I'll probably have to re-locate the panhard/track bar mounts to the 3:73 axle as well.
1972 Cheyenne Super, 383/TH350, work in progress
colinlx is offline   Reply With Quote
Old 01-18-2011, 09:35 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Rear Axle Swap
I'm not sure how that will work considering the 72 and prior axles have the panhard mounting bung cast in to the housing. You can use a universal mount like this one from Ride Tech Suspensions.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-18-2011, 11:31 PM   #3
Tmend
Tmend's Avatar
Re: Rear Axle Swap
Porterbuild make a nice set up all bolt in the panhard bar bolts to the trailing arms no need to weld or cut the diff. Also the have a set up for the shocks ass well no need to relocat them I just bought there. kit and nothing mounts to the diff cut off all brackets and smoothed out my diff looks sweet. Check out there sit
Tmend is offline   Reply With Quote
Old 01-18-2011, 11:32 PM   #4
colinlx
colinlx's Avatar
Re: Rear Axle Swap
Thanks, I should have looked at the axle a little closer first, I see now what you mean. Looks like this is the part to go with. Hoping to get at it pretty soon, can't wait to try it out with the 3:73.
Old 01-19-2011, 07:46 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Rear Axle Swap
I don't know why you couldn't use the super track bar from ECE on a a stock height truck. It's adjustable for length.
Old 01-19-2011, 09:24 AM   #6
colinlx
colinlx's Avatar
Re: Rear Axle Swap
Thanks Tmend, I'll take a look at their site too, do you have any pics of your set up?
Tx, I thought that was a little odd as well. I sent them an email yesterday but the person who replied didn't think it would work with stock height, though now that I re-read his email, it sounds like he's not too sure. I think I'll give their tech dept a call and see if I can figure out why.
Thanks for the help guys!
Old 01-19-2011, 12:34 PM   #7
robnolimit
robnolimit's Avatar
Re: Rear Axle Swap
We have the correct axle pads, and a long, bolt-on panhard rod. www.nolimit.net
robnolimit is offline   Reply With Quote
Old 01-19-2011, 01:38 PM   #8
Tmend
Tmend's Avatar
Re: Rear Axle Swap
no pics yet but the site has a complete set up pick section by section.. more details then my pics would have.. im sure he will also part out a kit he did it for me i purchesed the stage 2 economy kit without the c-notch and bags.. saves some good$$$$$$
Old 01-20-2011, 09:55 AM   #9
colinlx
colinlx's Avatar
Re: Rear Axle Swap
Thanks for the links guys. ECE wrote me back and were a little more specifc as to why their bar won't work. They said the bar would be too short to reach the bracket at stock height. The decline angle of the bar would also be too drastic, causing complications with the rear end geometery.
It's supposed to warm up here a bit in the next few days, I'll have to shovel the ol girl out and take some measurements. I'm alot further along than I was a few days ago though.
Old 01-20-2011, 10:57 AM   #10
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Re: Rear Axle Swap
Sorry for the hijack colinlx.
Robnolimit, what part numbers would we need to put a '75 axle in a '65 truck?
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
