Old 01-18-2011, 08:00 PM   #1
hdck07
hdck07's Avatar
Steel crank 327??
Looking at 68 LWB GMC tomorrow, wants me to make an offer.
AC cab
327
Tires are rotted off, hasn't been ran i a few years
His uncle bought it new...
says the rust is not bubbled up and only the rockers are in really bad condition in his add. I haven't asked any questions yet, figure I will wait til I see it in person.
He thinks that the 327 with a steel crank is rare. I don't know anything about this. Is there something I don't know?
I am so anxious to have one of these trucks I am afraid that I am going to over pay. I am thinking of offering $500 and going from there.[IMG][/IMG]
hdck07 is offline   Reply With Quote
Old 01-18-2011, 08:21 PM   #2
Re: Steel crank 327??
I wouldn't say the crank is real rare. I guess it's a fairly rare 327 crank. '68 was the last 327 truck motor and they were large journal (like 350s) with steel crank. I have one from a '68 Chevy truck. I assume this one will be the same casting. I don't recall the numbers but I ran mine down and its the same block as the '68 Camaro SS350 (350hp) and '68 Z/28. In my mind they are very desirable engines. They were rated @250hp.
Old 01-18-2011, 09:04 PM   #3
jakeblues652
jakeblues652's Avatar
like specialk already stated, there are large journals, and small journals. as far as i see it, all the small jornals are is a PITA to find another crank for. believe me, i have one sitting outside in a crate.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 01-18-2011, 09:35 PM   #4
crazy longhorn
Fabricate till you "puke"
An LJ 327 crank is pretty rare in a 2wd pickup....I have heard of guys pulling them from a 4wd, or BIG truck, but they were most common in muscle cars from the era. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-18-2011, 10:00 PM   #5
turp mcspray
turp mcspray's Avatar
All small journal 327 cranks were steel. A large journal steel 327 crank is pretty hard to find. I parted a 68 1/2 ton once upon a time, and it was a steel crank. You won't know if it's steel untill you pull the pan.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 01-18-2011, 10:15 PM   #6
hugger6933
steel as opposed to what ?wood? I asked that question long ago to someone looking for a crank . Well I thoght it was funny . Sorry . Jim
hugger6933 is offline   Reply With Quote
Old 01-18-2011, 10:55 PM   #7
Red68
Red68's Avatar
500 looks about right. The grill looks like it is in good condition and it is probalby worth about 1/2 that.
I just rebuilt my 327 and it was a large journal 69 out of a camaro.
Good luck.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 01-18-2011, 11:08 PM   #8
crazy longhorn
yup we found some balsa wood cranks in them chevs Ok done on joke time...Forged steel vs cast steel. Yes, they all had steel cranks....cast or forged crazyL
Old 01-19-2011, 12:07 AM   #9
heeroyue2002
fat old dude
heeroyue2002's Avatar
hmm i scrapped the 327 off a 64 impala ss 2 weeks ago
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 01-19-2011, 01:08 AM   #10
vectorit
What?
vectorit's Avatar
If you have a good eye and a flash light, and you can get under the engine and trans. Sometimes you can look up at where the crank meets the fly wheel, and if you see a wide cast ridge it's a steel crank. If it is a narrow cast ridge it is a cast iron crank.
Steel cranks, and 4 bolt main blocks are of no concern if you are just building a truck motor or even a hot little street thumper IMO.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 01-19-2011, 02:25 AM   #11
scrapmetalart
Junior Member
Just a little related hijack. Are 283 cranks small journal?
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 01-19-2011, 03:31 AM   #12
crazy longhorn
Yes....
Old 01-19-2011, 08:02 AM   #13
The first small blocks were small journal and smaller displacement(265,283,327). GM bumped the displacement up and went to a larger journal from that day on. All 305,307,350,400s,and the last 327s are large journal. I know in trucks the change occurred in '68 and,as far as I've seen,all these last 327/first large journals were steel cranks.
They say "steel" crank for forged steel which is stronger than the more common cast steel. I always said "forged crank",but the majority won out and I say steel now.
Old 01-19-2011, 12:09 PM   #14
hdck07
hdck07's Avatar
Thanks for the input, was supposed to call for directions today to meet him there at 10am, no answer though...
