Old 01-18-2011, 09:55 PM   #1
SOON2BLAZE
SOON2BLAZE's Avatar
No high beams :(
A few years ago I installed the headlight harness that classic industries sells to get more power to my gmc four eye headlights. On the way home the other night I hit my floor switch to kick on the high beams and SUPRISE.. no headlights at all. When I hit the switch again the low beams came back on. All connections are good, had some new high beams in the garage so I installed them...nothing. Wondering if it's one of the relays in the aftermarket harness. Any thoughts?
SOON2BLAZE is offline   Reply With Quote
Old 01-18-2011, 10:03 PM   #2
Sillyoldman
#16876
Sillyoldman's Avatar
Re: No high beams :(
I've had the same issues with a bad dimmer switch.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 01-18-2011, 10:03 PM   #3
swamp rat
swamp rat's Avatar
Is there any inline fuse blocks within the power wiring to the relays? start there.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-18-2011, 10:06 PM   #4
nonamecharlie
nonamecharlie's Avatar
I had that problem on one headlight, turned out to be just a bad connection on the back of the headlight.
1971 Chevy C20 Camper Special 350 V8
nonamecharlie is offline   Reply With Quote
Old 01-18-2011, 10:13 PM   #5
danleaman
my 72 C-20 did the same thing, a new dimmer switch fixed it.
danleaman is offline   Reply With Quote
Old 01-18-2011, 10:16 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I would start with turning on the highbeams, and kicking the switch, like from the side.
If nothing happens, then I would swap the two fuses and see if you have high and no low
If you still don't have highbeams, you need to start troubleshooting with a test light
Old 01-18-2011, 10:44 PM   #7
SOON2BLAZE
SOON2BLAZE's Avatar
Good idea. The reason I think the dimmer switch is still good is it still turns my high beam indicator light on in the speedo.
Old 01-18-2011, 11:25 PM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Mine did the same thing, bad dimmer switch.
John
1999 Toyota Tacoma 4x4
Old 01-18-2011, 11:28 PM   #9
Longhorn Man
high beam light in the dash comes on then the switch is doing its job. Go directly to the relay
Old 01-18-2011, 11:35 PM   #10
67chevy1series
67chevy1series's Avatar
my dad has that key word has
67chevy1series is offline   Reply With Quote
Old 01-18-2011, 11:46 PM   #11
VetteVet
Msgt USAF Ret
VetteVet's Avatar
You've got three wires going to the dimmer switch. The blue is the power wire from the headlight and has power any time the headlight switch is on. All you need to do is jumper the blue wire to the tan wire and see if you get any lights. Then jumper the green and blue wires and see if the lights come on. If you get lights when jumping both wires then the dimmer switch is bad on the high beam side. If you only get lights when jumping one of the wires then the problem is under the hood.
You may have burned out a relay or lost the ground to it. I have a diagram of the GMC headlight relay mod so if it isn't the dimmer switch then I'll post up the diagram .
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-18-2011, 11:54 PM   #12
SOON2BLAZE
SOON2BLAZE's Avatar
Nailed it Andy. Swapped relays and they both worked. Small amount of corrosion noted in one of them. Thanks to all for your replys!
Old 01-19-2011, 05:53 AM   #13
198ChevyGuy
What would it be if your high beam indicator on dash is on in either position? but when i go to click the high beams i lose my passenger side headlight
198ChevyGuy is offline   Reply With Quote
Old 01-30-2011, 05:26 PM   #14
71LWBFS
Thought I had same problem about a week ago I lost my highbeams, swapped in silverstars I already had and still no highs. So I started to do as vettevet said and pulled wire plug off of floor switch and as I proceeded to test the
I noticed that the housing had melted/broken/been ground down so that the highbeam (green i think)wire/connector was grounding out on the floor :/ I wrapped the plug housing with electrical tape to insulate it and it's all good now
71LWBFS is offline   Reply With Quote
