01-18-2011, 10:22 PM | #1 |
rear end replacement
can the rear axle out of a 93 chevy z71 go under my 66 c10 with minor adjustments.
01-18-2011, 10:26 PM | #2 |
Jonny
Re: rear end replacement
You'll at least have to ad perches for your leajs or trailing arms, whichever your truck has. check the distance from wheel mounting surface to wheel mounting surface and compare the 2.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
01-19-2011, 02:37 AM | #3 |
60-66 Nut
That '93 rear end will be a lot wider than your '66 rear end. IIRC it's about 2" per side, so ~4" overall. Other than that, you will have to do some cutting and welding with the trailing arm mounts. Then you'll have to fabricate a panhard bar mount.
