Old 01-18-2011, 11:02 PM   #1
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Need help measuring ride height to compare to other trucks
OK, Need a little help with my old body on late model frame.
In my Crew Cab build Young Frankenstein I am trying to figure out how to mount my body to the frame. I am measuring where my body height is and need some confirmation. I currently show 19 inches from the top of my sill/rocker to the ground. This is a good hard edge to measure from. Open your truck door and measure from level ground to the opening of the door - top of the sill or top of the "rocker". That first hard edge that the outer rocker firsts starts to roll into the door jamb. This is an easier measuring spot than somewhere on the curve of the rocker or the bottom pinch weld that varies somewhat. Follow me?
I have no weight on my suspension now and it will drop 3 inches with everything installed. (I measured another new truck). What distance is there on a stock truck? If a stock truck has rake measure at the front of the rocker near the fender. What distance do other people have with lowered trucks? Please list how much drop you have to help me convert the results.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 01-18-2011, 11:28 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Need help measuring ride height to compare to other trucks
Hey Drew,... since you have the ability to mount your cab wherever you want,...
Why don't you fix a GM problem,... and center those front wheels in the fender wheel opening.
(In your picture it looks like the wheel is too far back)
When the suspension compresses,... it's only going to get worse.
I just stumble on this thread and haven't seen your other thread. (yet)
Very cool project!
Keith
Convert to disc brakes.
Old 01-18-2011, 11:52 PM   #3
drewskiren
drewskiren's Avatar
Very cool project!
I am planning on that. In this early pic I have the cab just resting in place, not really lined up. Do you think I should put the wheel directly in the center or fudge toward the front?
Drew
Old 01-18-2011, 11:57 PM   #4
lolife99
lolife99's Avatar
I would pull the spring out and try to simulate ride height.
(maybe a stack of small 2x4's in place of the spring,... with a jack under the lower a-arm).
Or take the spring out and cycle the suspension all the way up.
That will give you the max rearward location of the wheel in the opening.
Keith
Old 01-19-2011, 01:59 PM   #5
drewskiren
drewskiren's Avatar
Good idea, I'll try it.
Still hoping some guys will measure for me.
Drew
Old 01-19-2011, 05:26 PM   #6
drewskiren
drewskiren's Avatar
Anyone can help.
Drew
Old 01-19-2011, 06:09 PM   #7
lolife99
lolife99's Avatar
Drew,... I have a comparable set-up.
Standard cab on a lwb "leaf spring GMC frame.
Stock suspension.
No front clip.
No bed.
No engine or trans.
26.5" tall tires.
17" from the top of the rocker,... to the ground.
Keith
Old 01-19-2011, 06:14 PM   #8
lolife99
lolife99's Avatar
If you are going for a static drop on the truck when you are done,... I would mount the body as low as possible, on your frame.
I would think it would depend on how low the engine/trans could be mounted,... and how low you can get your cab,... with a stock high hump trans cover.
(so you can use stock off the shelf carpet, up front)
Keith
Old 01-19-2011, 08:01 PM   #9
drewskiren
drewskiren's Avatar
Stock suspension.
No front clip.
No bed.
No engine or trans.
26.5" tall tires.
Thanks Keith!!!
I think I have it as low on the frame as I can go, and really had no idea if I was close to stock ride height or not. I plan on lowering and doing bags, But it won't happen til after I have committed on body mounts.
More input from others would be appreciated!!!
Drew
Old 01-19-2011, 08:14 PM   #10
drewskiren
drewskiren's Avatar
I have 30 inch tall tires on it right now, so it looks like Keith's measurements and mine are about the same.
I am really asking for someone with a finished truck lowered or not to send a pic and some measurements so I know what it looks like and what numbers off the ground are to shoot for. I am thinking a 2/4 drop truck would be perfect to get the tire and rocker measurements from, but any truck would be fine.
Drew
Old 01-20-2011, 12:22 AM   #11
drewskiren
drewskiren's Avatar
Stock suspension.
No front clip.
No bed.
No engine or trans.
26.5" tall tires.
Using your info I am about a quarter inch higher.
Thanks for taking the time to do this!!!
Drew
