Old 01-18-2011, 11:11 PM   #1
stealth_weapons
Rear End Gurus can i have a minute?
i am considering a swap from my current 63 C10 12 bolt rear end (pressed on back plates)to a Ford 9 inch. the reason is i want the 5X5 lug pattern and ease of changing gearing.
now my question is, what all is involved in the swap, what misc. parts might i need, and what about axle lengths (is there a certain length,car, or truck i should look for)
thanks for your help
after deciding on the rear end i will be upgrading all brakes to disc and adding wheels/tires.
stealth_weapons is offline   Reply With Quote
Old 01-19-2011, 01:53 AM   #2
blackedoutharley
Re: Rear End Gurus can i have a minute?
Measure your current rear end for the following:
axle to axle width
Backing plate to backing plate width
And then order a 9" from any reputable mfg. giving them the measurements they should be able to take care of you. The only other thing you will need that I can think of (other than brake stuff) is the weld on axle tube perches and a means to attach the panhard bar.
edit:
Moser engineering offers a complete Ford 9" rearend for our trucks.
http://www.moserengineering.com/
blackedoutharley is offline   Reply With Quote
Old 01-19-2011, 02:08 AM   #3
Captainfab
60-66 Nut
It's not going to be easy to find a OEM 9" that is 62" wide. Probably going to be from something like a Mustang or an early Bronco. Also regarding the 5x5 bolt pattern. The typical 9" is going to have a 5x4.5 bolt pattern, so the axle flanges will need to be re-drilled. If you're set on a 9", I say just have one narrowed to the right width and build it the way you want it. Also when building a rear differential, you can put whatever brakes and wheel bolt pattern you want on it.
Old 01-19-2011, 07:17 AM   #4
7T2
Active Member
7T2's Avatar
I've been told Lincoln rears are sometimes used if you want disc brakes. The rear end is about the same width and has the 5 on 5 bolt pattern. I have one of the housings and the flange to flange measurement is the same. Not sure what you have to do to get it to bolt up to your driveshaft.
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 01-19-2011, 07:19 AM   #5
283nova
dana 60!
283nova is offline   Reply With Quote
Old 01-19-2011, 09:38 AM   #6
lakeroadster
If you were to use stock style 64-66 axle perch's and then a Super Track Bar... should be a fairly easy install. (Super Track Bar eliminates the panhard bar mounting to the rear axle and moves it to the trailing arm.)
Also, if you go with a multi-lug pattern wheel many of them fit 4-3/4 and 4-1/2 bolt patterns. (I have Wheel Vintique Chevy Rallies and they are the dual pattern, as well as many racing type wheels have the dual pattern set-up.)
Sounds like an interesting build... keep us in the loop!
lakeroadster is offline   Reply With Quote
