Old 01-18-2011, 11:35 PM   #1
dtkarst
Frame Shortening Questions
Does anyone have any clue at all as to where a frame would need to be cut on a 63 LWB, in the proper place that is, to make a long bed to a short? I have the long bed stripped down to the frame and I am waiting for my brothers 63 shortbed to get to that point so i can set them next to each other and take a look. Just seeing what it would be like from people who have more knowledge on it. Thanks
dtkarst is offline   Reply With Quote
Old 01-19-2011, 02:25 AM   #2
Captainfab
60-66 Nut
Re: Frame Shortening Questions
I like to cut the frame just a little forward of the rear cab mount. Of course you will have to move the rear cab mount rearward after the frame is shortend.
Be sure you get good penetration with your welds, and fishplate the joint properly. You don't want that coming apart on you.
Old 01-19-2011, 03:33 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Trucks TV ran a segment in 2007 that show exactly how to do this, both to the frame and the fleetside bed. You can watch it on Amazon.com for $1.99, and save it to your hard drive. Following is the link. It's episode 10 dated 5/27/2007, titled 1/2 a C-10.
Amazon.com: Trucks!: Season 2007, Episode 1... Amazon.com: Trucks!: Season 2007, Episode 1...
Old 01-19-2011, 06:44 PM   #4
dtkarst
For what year of a pickup?
Old 01-19-2011, 06:47 PM   #5
SCOTI
SCOTI's Avatar
Originally Posted by dtkarst View Post
Does anyone have any clue at all as to where a frame would need to be cut, in the proper place that is, to make a long bed to a short? I have the long bed stripped down to the frame and I am waiting for my brothers shortbed to get to that point so i can set them next to each other and take a look. Just seeing what it would be like from people who have more knowledge on it. Thanks
Krue FAQ index list in the FAQ section. This is how I did mine....
http://67-72chevytrucks.com/vboard/s...d.php?t=123624
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-19-2011, 07:35 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Thanks for sharing that thread. In all the earlier threads I've seen on this topic I've never seen that one mentioned before. It's the most detailed and comprehensive how-to I've read in a long time.
Old 01-19-2011, 07:44 PM   #7
SCOTI
SCOTI's Avatar
It sure is.
I did things a little differently, but if you look through the early pages of my build, you can see how easy it was to duplicate. I simply printed off that thread/post, put the pages into a binder, & used it as my 'how-to' guide to make sure I didn't screw things up.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-19-2011, 09:10 PM   #8
dtkarst
Good work on that frame. But would that be the same for a 63? If it is, that is basically like a play by play haha
Old 01-19-2011, 09:32 PM   #9
jocko
jocko's Avatar
Amazon.com: Trucks!: Season 2007, Episode 1 "2007 Silverado buildup": Video On Demand
Quick add-on - that TRUCKS series (i.e. ALL the episodes) was really, really good. And I've actually asked the powerblock crowd when/if they are ever gonna release a start to finish DVD for that build like they have for all the other trucks and cars they've built. They wrote back and said it would be out sometime this year. I'll buy it!
Old 01-19-2011, 09:46 PM   #10
SCOTI
SCOTI's Avatar
Yep, same thing.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-26-2012, 06:57 PM   #11
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Someday I think I'd like to make a medium bed.
That is, I'd like to shorten a fleetside bed to 7 foot.
I don't know.... I sometimes think the fleetside longbeds look a little too long, and the fleetside shortbeds look a little too short.
66 C20 Service Truck:
Old 09-27-2012, 03:40 AM   #12
argonaut
argonaut's Avatar
Cut a 12" section out. The spot directly underneath the cab has the least stress on it, so the best place to put a joint. Grind the edges of the weld joint almost to a point so that you are welding back into a V on both sides. Use the appropriate stick, TIG or Flux Core welder with good heat and penetration. Make the passes slow and wide for good coverage. The strongest joint would be to leave the weld bead on the outside, and fish plate the inside. You want the fish plate to be notched at each end like so: >< that way you don't create high stress points in your frame.
Although, if this is a just a street cruiser, and not towing, hauling, racing or off-roading, then all of this is probably even overkill. You could just weld the joint and be done with it.
There are some photos of how I did mine in my 4x4 build thread. Although I made the cut behind the read cab mount because the 4x4 frame tapers and gets taller underneath the cab.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 03-24-2018, 11:56 PM   #13
LostMy65
LostMy65's Avatar
Has anyone used these?
https://www.summitracing.com/parts/c...2rfs/overview/
Old 03-30-2018, 09:42 PM   #14
rvrfoot
I cut my frame.
rvrfoot is offline   Reply With Quote
Old 03-31-2018, 01:07 PM   #15
DLW
Originally Posted by LostMy65 View Post
I have those sitting in the garage. They fit inside the frame so depending on where you cut the frame will determine if anything is in the way of using them. For me I would need to do some trimming on my PB trailing arm cross-member mounts, where they bolt to the frame. They are stout pieces though and would work nicely for some extra strengthening.
DLW is offline   Reply With Quote
Old 03-31-2018, 02:16 PM   #16
LostMy65
LostMy65's Avatar
Thanks, I'm shortening a longbed frame, and I just wanted a little extra security for my welds.
Old 03-31-2018, 11:22 PM   #17
Captainfab
60-66 Nut
In the past, I just cut a piece of 10ga to the shape I wanted and stitch welded it to the inside of the web of the frame.
Old 04-01-2018, 12:17 AM   #18
rvrfoot
Brothers sells a kit that i got.
Old 04-25-2018, 10:56 PM   #19
LostMy65
LostMy65's Avatar
I got my ccp stiffeners from summit today.
Very tight fit. So tight, I was at first concerned.
But they fit so tight, I had to tap them in with a hammer.
They are pretty heavy duty too.
Now to cut a perfectly good longbed frame in half.
Old 04-25-2018, 11:34 PM   #20
rvrfoot
No problem cut away. I did mine.
Old 04-26-2018, 08:22 PM   #21
hotrodder
Thumbs up Re: Frame Shortening Questions
I think the medium frame is a great idea! Some one needs to do that. Like they say "If you aren't the lead dog the scenery never changes"
hotrodder is offline   Reply With Quote
Old 04-26-2018, 08:48 PM   #22
LostMy65
LostMy65's Avatar
http://www.67-72chevytrucks.com/vboa...d.php?t=594691
Old 04-26-2018, 11:16 PM   #23
rvrfoot
I shorten mine i will see if i can find the pictures.
