Old 01-19-2011, 12:39 AM   #1
69CSTDawg
69CSTDawg's Avatar
spedometer calibration question
ive seen in the summit catalogs the speedo recalibrator for 92 n newer trucks with electronic transmissions,is there anyway to correct the speedo on older trucks like speedo gears with fewer or more teeth or anything else? or an aftermarket speedometer?
69CSTDawg is offline   Reply With Quote
Old 01-19-2011, 02:22 PM   #2
Plunkett
Re: spedometer calibration question
You can correct your mechanical speedometer by changing out the drive or driven gear in your transfercase. I believe Bowtieoverdrive.com has a calculator to tell you which one you need to replace.
1987 gmc sierra v1500. 350 tbi, 700r4, 6" sky jacker lift, 15" Mickey Thompson wheels, and 35" bf Goodrich km2 tires.
Plunkett is offline   Reply With Quote
Old 01-19-2011, 10:07 PM   #3
msgross
msgross's Avatar
There is also a ratio adapter... they come in all ratios...
http://www.transmissioncenter.net/sp...atio%20adapter
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-19-2011, 11:08 PM   #4
69CSTDawg
69CSTDawg's Avatar
thanks for the info,looked on bowtieoverdrives.com and they had the gears for 700r4s and 200r4s will those work for others like TH400s? and which do yall think works better? gears or adapters?
Old 01-19-2011, 11:18 PM   #5
Zoomad75
K5Camper
Zoomad75's Avatar
If you can't find the right gear combo you can use a GPS in a pinch until you do.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 01-19-2011, 11:29 PM   #6
Plunkett
I think tci's website also has one.
Old 01-20-2011, 11:52 AM   #7
pseudopimp
pseudopimp's Avatar
is there a way to know what drive gear you have without taking your transmission out of service? i would like to just order the correct driven gear tooth for my application, but don't know the drive gear.
84 Scottsdale LWB K10
Rooting against the cowboys is almost as fun as rooting for the GIANTS!
pseudopimp is offline   Reply With Quote
Old 01-20-2011, 12:47 PM   #8
Plunkett
You can take the driven gear and housing assembly out and try to count the teeth on the drive gear or try and see what color it is and that might help you. For some crazy reason, my truck had a 10 drive gear, so I had to replce the drive gear to get my speedo right.
Old 01-21-2011, 04:23 PM   #9
pseudopimp
pseudopimp's Avatar
i thought you had to remove the tail housing to do the whole swap. is this correct? or can i just take out the housing assembly....that sounds too easy.
Old 01-22-2011, 12:08 AM   #10
Plunkett
It depends on which gear you have to replace. I had to replace the drive gear on my tc, so I had to pull the tailshaft off my tcase. It was really easy to do tho.
