01-19-2011, 01:26 AM | #1 |
disk brakes for rear need advice /help thanks
i am wanting to turn my truck to disk brakes in the rear ,it already has disk in th front but would like to convert the back to disk as well would like to be able to go to a junk yard and just rape parts off a newer tahoe or somthin would like to be safe but cheap as can get it , thanks rick
01-19-2011, 01:30 AM | #2 |
What?
Re: disk brakes for rear need advice /help thanks
Check these guys out: http://www.blackbirdscustomtrucks.com/
They do rear brake conversions just for our trucks, and I have done a little business with them and I was very happy with their service. I think they are a board vendor too.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
01-19-2011, 01:32 AM | #3 |
thank you !
01-19-2011, 07:56 PM | #4 |
6 lug or 5 lug. There are several ways to do this. I converted mine with the LT1 F-body calipers and brackets from board vendor Captianfab. My truck is 5 lug.
Here is one of Cap's threads Check his sig for more options. http://67-72chevytrucks.com/vboard/s...d.php?t=398352
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 01-19-2011 at 07:59 PM. |
01-20-2011, 12:53 AM | #5 |
i am running 72 5 lug suspesion so i will need parts that will comply with 72 suspesion
01-20-2011, 02:07 AM | #6 |
Take a look at a front or rear rotor for a 69/78 Cadillac Eldorado or 69/78 Olds Toronado
They are pretty common an not all that expensive. If you use the 76/78 Eldo rear calipers they have parking brake pieces built in. You would still have to come up with caliper brackets but that shouldn't be that hard. |
01-20-2011, 09:48 PM | #7 |
thanks were would i be able to get brackets to comply with those calipers and my axle also would i still be able to run my 72 steel rims
01-20-2011, 11:15 PM | #8 |
I just bought the brackets for the caddy swap from a guy in mid west i believe.....I'll find the name and a pic of them mocked up . I needed to turn down the axle flange to fit the caddy rotor but that was about the hardest part. They are call steel tech solutions, he makes a nice bracket , takes a bit of time to get them, but they worked perfect www.steeltechsolutions.com
01-20-2011, 11:24 PM | #9 |
thanks man those look awsome i am looking forward to putting disks on the back drums are so complicated! and disks are easy to install!
01-20-2011, 11:53 PM | #10 | ||
Happy to be here
******Captainfab******
01-20-2011, 11:55 PM | #11 |
thanks n2trux!
01-20-2011, 11:56 PM | #12 |
was that sopposed to be a link ? if so it is not working
01-21-2011, 06:20 PM | #13 |
The link is in my original post. It is also in the quote of my original post that n2trux posted. Here is is one more time. Click this link and look at CaptainFabs signature. This will get you headed in the right direction. There are several different ways to do this conversion. All have their pros and cons. The Cadillac calipers are bad about the e-brake not working after time. The Impalla calipers have no e brake provision. The F-body calipers are a nice piece and have an e-brake. All the info is out there You just got to dig a little. CaptainFab sells the brackets. He is great to deal with. Good luck on your project.
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 01-21-2011 at 06:27 PM. |
01-21-2011, 06:31 PM | #14 | |
01-21-2011, 06:47 PM | #15 |
Fabricate till you "puke"
Nice catch Fitz.....nobody else looked that close Yes the bleeders do need to be on top to expell the air from the system. Maybe a couple too many Badwieser's (been there, done that) Nice looking setup,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
04-26-2011, 01:24 AM | #16 |
Wow , it only took me this long to realize that someone else saw the pic's. That's not the bleeder valve, that is a cut off brake line that is sticking out. The bleeder is on the top in the front half that can't be seen. The Caddy calipers are marked "L" and "R"... ( Had to run down and look at the one on my work bench to double check)
04-26-2011, 07:28 AM | #17 |
Redefining LowBudget
ok dumb question???
how does the e brake work?? does it clamp the pads or is it in the disc like others I have seen
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
04-26-2011, 09:43 AM | #18 |
It clamps the caliper to the rotor. There is an arm that comes off the back of the caliper.The arm has a mechanism in side the caliper, when it is pulled it pushes the piston outward and clamps the pads on to the rotor
