Old 03-23-2002, 05:06 PM   #1
j-dogg
Post Need info on swaybars
I need a swaybar for my 87 1 ton crewcab single rear wheels. Are the swaybars and brackets on duallys the same? There are several duallys in a local junkyard I could take a swaybar and brakets from. How about a regular 3/4 ton swaybar? And are there differences between 73-87 swaybars and brackets? Any info you want to give I will certainly use!
[This message has been edited by j-dogg (edited March 24, 2002).]
j-dogg is offline   Reply With Quote
Old 03-24-2002, 01:45 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
your needing this for the front, or the back?
Up front, they should all be the same from '67 - '87 1/2 ton - one ton. The bigger the truck, the bigger and better the bar.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
Need to pick up the one ton Longhorn with a PONTIAC 350/350soon.
Thanks every one!
Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 03-24-2002, 02:45 PM   #3
j-dogg
Post
Yes, up front. Thanks for the info.
