Old 01-19-2011, 06:15 PM   #1
roofingbloke
sway bar with air bags ??
Hi All, I have purchased an after market swaybar from cpp but at the time i was running coils but will soon be running air bags with stock a arms,
Will this work ok.
PS; thinking of sectioning the front crossmember 1.5"
roofingbloke is offline   Reply With Quote
Old 01-19-2011, 06:18 PM   #2
tech@scottshotrods
Re: sway bar with air bags ??
absolutely! if it is an oem style replacement beefed up we can get you the posi end liks from air ride which will eliminate any kind of bind and keep a positive engagement
tech@scottshotrods is offline   Reply With Quote
Old 01-19-2011, 10:37 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Will this work ok.
I'm running the CPP bar with endlinks and bags on my 'burb. The kit came with two sets of front bar mounts. I ended up using the taller mounts as they fit better than the short set. Dont know why....
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
