Old 01-19-2011, 07:24 PM   #1
lakeroadster
'65 Anti Theft & Ignition ACC Toggle Switch
Our trucks don't have an ACC position on the ignition switch. Therefore if you turn the ignition on to listen to the radio, without the enigne running, you may burn up your coil and your points.
What if a fella was to put a toggle switch on the hot wire that goes from the ignition to the coil? If the location of the switch was in an accessible, but hidden, location in the cab it could also be used as a theft deterent?
Fix one issue, get a bonus feature for your efforts.
What say ye gang, sound like a workable scenario?
(This would be better than just a "non ignition" hot wire to the radio. Do that and forget to turn off the radio and you get a dead battery.)
John
lakeroadster is offline   Reply With Quote
Old 01-19-2011, 08:21 PM   #2
iiizman
iiizman's Avatar
Re: '65 Anti Theft & Ignition ACC Toggle Switch
In my old truck i put a micro switch that i hooked a relay behind, so I could power all my accessories. The button was small and I put in the ashtray. The relay just redirected the power straight to the battery.
Bad Decisions usually make for Good Stories.
iiizman is offline   Reply With Quote
Old 01-19-2011, 09:39 PM   #3
Big Fenders
Lakeroadster...Seems like you'r talking about two different things...Ignition cut-out switch and constant power to the radio. As said ,no accessory position on the ignition switch...what I did was wire in a constant hot [toggle switch ] with an LED indicator light to remind me that it was on. The coil cut-out switch is also a good idea...just an extra level of theft deterrent.
Bob
Big Fenders is offline   Reply With Quote
Old 01-19-2011, 09:51 PM   #4
lakeroadster
Originally Posted by Big Fenders View Post
Lakeroadster...Seems like you'r talking about two different things...Bob
Correct: two different benefits from making one change.
  1. Want to listen to the radio when engine is off? Flip the toggle switch and turn the ignition on.
  2. Want a theft deterent? Flip the toggle switch.
Make sense?
Old 01-19-2011, 10:45 PM   #5
iiizman
iiizman's Avatar
Why not a small three position toggle with relays on both sides of the switch. That would let you use the small switch and wiring the relays to do what you want. I later hooked mine to the outputs of my VSE alarm, which I liked better. There are alot of creative people on here. I am sure someone will come up with some good ideas.
Old 01-19-2011, 11:33 PM   #6
62ShortStep
62ShortStep's Avatar
Make sense?
Makes sense to me, and its simple too. Think I'll do that to my '62.
Doh! That rhymes! I've done that so many times.
Doh!
62ShortStep is offline   Reply With Quote
Old 01-19-2011, 11:45 PM   #7
Heater63
Heater63's Avatar
I've wondered for some time how to do this. I definitely want a hidden "kill" switch, and the "acc" feature. I like your ideas- who is a resident electrical guru on our board?? We need to PM them to jump in- I like to be spoon fed when it comes to relays and wiring schemes! LOL
292 + TKO500
Heater63 is offline   Reply With Quote
Old 01-19-2011, 11:48 PM   #8
cb1965
cb1965's Avatar
i have a toggle switch that cuts power to my coil. from ignition to toggle switch to coil. simple and effective
cb1965 is offline   Reply With Quote
Old 01-20-2011, 01:35 AM   #9
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Yep, that would work fine. All I need now is a radio to listen too.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-20-2011, 02:52 AM   #10
62ShortStep
Lakeroadster- I work with some engineers who sometimes forget the basics of designing. Even though many people can come up with deigns that work, the trick is to accomplish a design with as few parts, complexity, and resources as possible. The rewards are reliability, quick implementation, ease of use, and cost effectiveness. Thanks again for a good idea.
Old 01-20-2011, 03:02 AM   #11
juanz1947
rusty 66
juanz1947's Avatar
Talking Re: '65 Anti Theft & Ignition ACC Toggle Switch
sound like some thing i need to do
1947 chevy fleetmaster
http://www.cbforum.net/forum/
1966 chevy c10 long bed
http://67-72chevytrucks.com/vboard/s...d.php?t=439219
1970 chevy impala custom
http://www.layitlow.com/forums/index...pic=349867&hl=
juanz1947 is offline   Reply With Quote
Old 01-20-2011, 10:01 PM   #12
Big Fenders
Make sense?
That would work as long as the toggle is switch is hidden from view.
Bob
Old 01-20-2011, 10:27 PM   #13
SCOTI
SCOTI's Avatar
Bob
Or even better, hidden in plain view.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-21-2011, 08:52 AM   #14
lakeroadster
Thanks for the post. I used to make a living as a Mechanical Engineer. I miss working with customers and the guys on the shop floor. Mutual respect.... I always seemed to get along with the end users and the product builders, and a big part of that was based on what you posted. One of the things I always told my managers was to "stop hiring Engineers that don't have enough mechanical aptitude to change the tire on their own vehicle".
I worked with way too many engineers in my career that had chosen the incorrect path on the yellow brick road, so to say.
Bob
I have a buddy, Kevin Erisman, back in Ohio who does suspension modifications http://www.hackersparadise.biz/index.html Kevin will lower any and every kind of vehicle. One of his signature modifications is locating the air ride suspension controls into the orignal vintage radio. Basically by pushing in on the frequency set buttons you can air up or air down the suspension.
Neat stuff!
