Old 01-19-2011, 08:54 PM   #1
496 BB
496 BB's Avatar
78 K20 Payload
What will these frames handle as far as weight in the bed? I wanting to put a Vbox salter in the bed and not sure of frame. Frame is in perfect condition without a spec of rust (Por 15). I plan on using air bags for the suspension that are rated at 5K# a bag. Ive got em on my HD and they are great. The total weight of this box with 2 cubic yards of bulk salt would be around the 3200lbs-4000lbs range. I know this is alot but have seen many with same setup on newer (90s) 3/4 tons. Wasnt sure on these. Will I have to go with a 1 ton frame?
Thanks,
Chris
1985 Chevy K-20
350ci (8.1L in the works!)
NP203/TH400 (Soon to be 205/400)
Dana 44 and 14 bolt FF
7.6' Western Plow
2001 Silverado LT HD 4x4
496ci (8.1L)
Allison
EFI Live
And more.....
496 BB is offline   Reply With Quote
Old 01-20-2011, 10:50 AM   #2
496 BB
496 BB's Avatar
Re: 78 K20 Payload
Noone knows?
1985 Chevy K-20
7.6' Western Plow
496ci (8.1L)
Allison
EFI Live
And more.....
Old 01-20-2011, 11:13 AM   #3
cochino12
It followed me home?
cochino12's Avatar
Re: 78 K20 Payload
sorry I'm not much help with the payload, but what kind of spreader are you using? I'm thinking about a buyers poly unit for one of my flatbeds.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-20-2011, 01:40 PM   #4
496 BB
496 BB's Avatar
Re: 78 K20 Payload
Same thing...lol. 2 cubic yard electric motor. $3100. I got some on my other guys trucks and they are very nice.
1985 Chevy K-20
7.6' Western Plow
496ci (8.1L)
Allison
EFI Live
And more.....
Old 01-22-2011, 03:18 AM   #5
Gregs71
Re: 78 K20 Payload
I believe there were two different k20's, a light duty-GVWR 7200lbs, and a heavy duty 8600lb GVWR.
My 87 k20 has a payload rating of just under 3000lbs and it has a GVWR of 8600 and is a camper special.
Not sure what the payload is for a 7200lb GVWR truck
1995 GMC 4x4 1/2 ton
1999 Jeep Wrangler w/ 33's
68 camaro 350/350
1987 Chevy 3/4 ton 4x4
Suzuki DRZ 400s Dual Sport
1971 chevy long bed 2x4
194? Dodge 2.5 ton
1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455
1989 Chevy V30 crewcab dually 454/TH400
Gregs71 is offline   Reply With Quote
Old 01-22-2011, 08:23 AM   #6
RuralRoute C-30
RuralRoute C-30's Avatar
Re: 78 K20 Payload
From another source this might help:
"K/20 models were available with GVWR from 6,800 - 8,400 pounds, as in earlier years."
There is a chart on payloads on this link for at least the '77's. Should be comparable.
http://www.chuckschevytruckpages.com/models.html
Not sure it definitively answers your original question but the knowledge is free.
My opinion is that the hopper weight will be minimal. Once installed though, you might have to regulate how you initially fill it to 3/4 full vs. 100%. I'd hope the tires are in good shape too. It'll probably take some 'experimenting' but it should work. Just not sure if you will be able to load it to the max.
Good Luck with it.
Mark
1985 Chevy C-30 Hydraulic Dump Bed
2001 Saturn SC2 (go to work car)
2010 PT Cruiser (wife's car)
"Reality is just a hallucination brought on by lack of alcohol."
RuralRoute C-30 is offline   Reply With Quote
Old 01-22-2011, 11:56 AM   #7
496 BB
496 BB's Avatar
Re: 78 K20 Payload
Thank you for the answers. I will just build it accordingly. The tires are rated for it and the airbags will handle it also. Just didnt want the frame to buckle...lol.
1985 Chevy K-20
7.6' Western Plow
496ci (8.1L)
Allison
EFI Live
And more.....
