not enough hours in the day
Engine Miss - I could use some help
I've been trying to track down an engine miss and am running out of ideas and tired of throwing money at it. I'm hoping for a little guidance.
It's your standard 350 with electronic ignition. It was running fine then one day when I went to leave work for lunch it had a miss. It stays the same if the engine is cold or warmed up. I've replaced the gasket between the carburetor and intake which was leaking, new cap and rotor and new plugs. The plugs were only a few months old. #4 had black carbon deposits, #6 had some rust colored coating on it and the others looked normal. I have not replaced the wires yet, they were replaced last summer with the plugs and like I said, I'm tired of throwing money at it and not fixing the problem. I have checked them over and can't see anything visually wrong with them. I did a compression check and all cylinders were at 115-125 psi. It does have a cracked exhaust manifold on the LH side that is a recent development. Could this cause a miss? Any ideas? Edit: I forgot to mention that the miss is present at an idle and when under load. Last edited by jasons; 01-20-2011 at 10:36 AM. |
What?
Re: Engine Miss - I could use some help
Those two 4 and 6 plugs, would have me concerned. Is the crack in the exhaust manifold on the same side as the 4&6 holes? If so, then the crack could be causing a problem. Is your exhaust popping on deceleration, such as crackle n' pop? If so, you could have an exhaust leak that could be causing 4&6 to foul up like you describe.
Could also be as simple as a defective plug wire, and I would again focus on 4&6. Just a thought.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
yes, i do
your compression numbers look a little low too. for most healthy stock motors the norm is about 150psi. your compression has me a little worried
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 Last edited by 60ratrod; 01-19-2011 at 10:57 PM. |
Take a spray bottle of water and spray the wires at night when the truck is running and look for a spark. This is a free test
Fuzzy |
#5 | |
After a little research I discovered the throttle should have been wide open. I did my test with the throttle closed. I'll have to do it again. I would think the numbers will be higher, but the important thing is they were all about the same.
have you changed your fuel and air filters recently?
I have heard of a fuelmiss befor is this just a idle thing or is it through the rpm range? you may just need to retune the carbs maybe the idle mixture ?
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
[QUOTE=Willys47;4425315]I have heard of a fuelmiss befor is this just a idle thing or is it through the rpm range? you may just need to retune the carbs maybe the idle mixture ?[/QUOT
It is through the rpm range, and is present under all driving conditions. |
Pull the plug wires one at a time with insulated pliers. The weak cyl. will not effect the RPM like the good ones do. Pull the valve cover on the suspected cyl. & check the height of the spring. A recessed valve seat sometimes will not show up in a comp. check. Turn the engine over & watch if any valves do not open near as much as the others. That would signify a worn camshaft. If you isolate it to a particular cyl. you can check that plug wire with a ohmeter. How about the dist. cap. Often you can not see a carbon track.
